Home > Puma (Tdci) > Still with problems in high temps :cry:
Page 2 of 2 <12
Glynparry25
I will add that a remapped puma 2.4 will have plenty of grunt at that slope and would easily cruise over 2k (60mph)..
Glyn Dog Sheep
Post #286089 28th Nov 2013 8:25pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Something as simple as wind direction can have a big effect. In 6th, an overdrive gear, the fan would be running slower as the engine is turning over slower. Big difference in cooling effect between driving into the wind compared with driving with the wind.. Using 5th gear, which is a direct gear, gives a higher engine hence fan speed so wind direction has less of an effect.
Could this have a bearing on your problem? Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #286092 28th Nov 2013 8:30pm
Eduardo
Thanks Welshgas
Despite to be a very windy zone I dont remember that this day were too windy.
Anyway it is safe to try the reply the fault again with the ODBII connected to see the parameters? or simply forget it and try to use the 5th gear when a slope appears?
Cheers and thanks again for the ideas Thumbs Up Eduardo
Post #286099 28th Nov 2013 8:38pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
I think it will be "safe" to try and replicate the fault.
This system is in place so that (hopefuly) no matter how hard you try, you should not be able to overheat the engine.
You will probably notice a drop in feul rail pressure as well as a drop in boost pressure. This will be in conjunction with a high CHT, Coolant temp and high Manifold intake temp.
Post #286171 29th Nov 2013 6:10am
Eduardo
Thumbs Up
I will try again to see how the fault occurs and if I have some early indicator.
Cheers! Eduardo
Post #286216 29th Nov 2013 10:18am
K9F
Morning Eduardo, (well it is for me anyway Cool,
Each time I go to Kent coming back after Clacket Lane services on the M25 there is an incline of about 6 miles. Tackling it in 6th gear (which is really an overdrive/cruising gear) the engine temperatures do rise significantly. Changing down to 5th immediately always drops the temperatures significantly and the truck pulls much better. (I am monitoring on a Scangauge2 just for interest.) I personally don't think in your circumstances you have much to worry about and check the figures in comparison next time using 5th instead of 6th, or do a comparison as stated in both gears if you have the time and inclination. Me I wouldn't bother until I have to travel that route again.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #286223 29th Nov 2013 10:28am
Eduardo
KF9,
Morning to me now.
Thanks for the advice, in fact probably I will do the same route in the next 3-4 weeks so i will check there.
I will connect my ODBII to be sure.
Regards Eduardo
Post #286246 29th Nov 2013 12:32pm
Page 2 of 2 <12
