Home > Maintenance & Modifications > wheel arch liners
myonehere
2007 Defender 90 Puma 2.4 HT Cairns Blue
wheel arch liners
I transferred some from my last 90 - but also added some more. They make a HUGE difference - stopping the rubbish from getting everywhere.
Post #285924 28th Nov 2013 11:16am
MartinK
They look good Thumbs Up
Stop a lot of noise from the rear wheelarches (especially in the rain) as well I suspect ? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #285925 28th Nov 2013 11:17am
myonehere
they do indeed - although the heavy sound-deadening kit does that too ...
Post #285927 28th Nov 2013 11:20am
mk1collector
Can you get 110 rear arch liners?
Post #285940 28th Nov 2013 12:30pm
myonehere
'dunno - but made mine myself with rubber sheet - and some cast off lorry mudflaps
Post #285955 28th Nov 2013 1:23pm
Norm4n
Where can you buy these from?
Assume they are very robust and wont crack up with large stones clattering into them?
Post #285956 28th Nov 2013 1:24pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Yes I'd like to know if they fit 110 and where are they from?
Post #285957 28th Nov 2013 1:24pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
The front liners you can get from Landrover as they come fitted as standard on some models. The rears look to be made from HGV spray suppression mudflaps which you can buy from a commercial motor factors or the likes of Ebay. They are very robust and should not crack and will reduce road noise and the rain in the wheelarch sound you get driving in the rain! You would have to cut them down to suit then find a means of attaching to the inner wing. Shouldn`t be to difficult to do and would be a very worthwhile mod that won`t cost the earth to do. They should also help protect the rear crossmember from crud as an added bonus which can only be a good thing! Very Happy
Post #285967 28th Nov 2013 1:38pm
myonehere
yes - as said below [above] = lorry mudflaps- trimmed carefully they need minimal fastening as they are held by the lip above the 'eyebrows'. Served me very well on the last two Defenders. No reason you cant fit to 110 as well...
and yes, stops all the muck going up over the chassis crossmembers too.
Front ones are held by the existing screws holding the inner plastic wing
Post #285981 28th Nov 2013 2:30pm
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Also very interested in this mod, as I have discovered corrosion holes around the rear seat mounting brackets in the wheel arch of my 110. I can only think from stones and crud being thrown up into the arch from the tyres. Thanks for posting.
Post #286200 29th Nov 2013 9:21am
epictrail
Here's the front arch liners.
Only problem is they cost around £152 each Shocked
Post #286321 29th Nov 2013 6:12pm
myonehere
mine cost about 50p I think -
Post #286451 30th Nov 2013 8:32am
Naks
I'd like to do that as well. We drive on lots of gravel roads, and the noise from the gravel being flung up and hitting the wheel arches can be quite loud and gets on one's nerves after the first 100km.
I have heard of people who use a spray-on rubber? --
Post #286459 30th Nov 2013 8:55am
Cheshire110
Don't all defenders have these fitted? I've never seen one without? They separate engine bay and the wheel so there has to be something there.
Both my 200tdi 90 and tdci 90 and tdci 110 all had them fitted anyway.
Yes it would be fairly easy to trim a big standard car mudflap and bolt it to the front of it I guess too Cheers, David
Post #286463 30th Nov 2013 9:19am
GUM97
All Defenders have inner wheel arches as standard An engine to TDi for!
Post #286580 30th Nov 2013 5:05pm
