Home > In Car Electronics > How to get rear speakers in a truck cab? (TD5)
Hock
England 2014 Defender 110 Puma 2.2 XS CSW Java Black
I know there aren't any normally fitted, but does anyone have a wiring diagram or write up for connecting a set to the standard ISO? (if this can be done?)
I'm basically looking at having a speaker behind the driver/passenger seats to better the sound and hopefully I might be able to hear the radio on the motorway then lol
Post #285913 28th Nov 2013 10:27am
farmer giles
hi hock,
have you got a headlining in your truck cab? as it maybe easier to piggyback off the existing dash speakers and run cables up the a pillars to the roof. Apair of quality 4" midrange and a pair of tweaters be better to listen to at high level.
anyway pm custon steve or barbel jim for technical details. Thumbs Up
Post #285923 28th Nov 2013 11:14am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Just look up ISO wiring on google, and wire in two rear speakers. Couldn't be simpler than that.
Steve
Post #285932 28th Nov 2013 11:49am
It would be possible to not have to do that and use the RCA pre outs, use a stereo Amp and then two speakers. If you wanted a Sub too just use a splitter or daisy chain it. Either method works.
Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #285951 28th Nov 2013 1:13pm
Hock
Don't really want to go into adding an amp etc, space is tight as it is.......and I'm no auto electrician lol
Whats the best way to connect to the wires for rear speakers (believe I'd be looking for the purple and green according to diagram below)
Searching through google theres options of exposing the wire and soldering, scotch clips or adding iso ends to the speaker cable and plugging in directly?
Looks like the scotch clips are easiest but no idea what the sound would be like, soldering could be a faff......hhhmmmm....maybe I should just sing to myself in the truck lol
Post #285963 28th Nov 2013 1:30pm
What do you have in there right now? Just the fronts with the rear wires present that need extending or is there no rear output wire "tails" so to speak?
I am assuming that it is ISO connectors you have. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #285966 28th Nov 2013 1:36pm
roel
Is there space for speakers in a truck cab?
I like the looks especially with the ifor Williams canopy but I couldn't sit nicely behind the steering wheel so the first thing I did was changing it in a Hard Top. Roel
2003 90 Td5 (2009-now)
Post #285971 28th Nov 2013 1:48pm
Hock
not taken the stereo out recently, but its an aftermarket HU with an iso connector. As far as I'm aware there are no cables for the rear speakers fitted as standard, hence why I ws thinking of tapping into the iso with new speaker cable.
As for space i should be able to get a speaker behind each seat, but yet, its a tight fit, especially when you're 6'1 lol
The ones I'm looking at droppping in are a set of shelf mounted (stand alone) jobbies I have left over from the old defender
Post #285999 28th Nov 2013 3:24pm
Hock
Sorted Smile speaker cable from halfords connected to ISO purple and green and we now have a bit richer sound, thanks Smile
Post #286106 28th Nov 2013 8:58pm
