![]() | Home > Maintenance & Modifications > Anti Roll Bars |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 ![]() ![]() |
I'd personally keep the standard front ARB - but use uprated mounts (SuperPro are my chosen option), but I would upgrade to a thicker uprated rear bar - again with uprated mounts. I have also played around with solid ARB mounts, which make a huge difference even with standard bars - but aren't really suitable for road use. You'd be more than welcome to come and drive my Puma Demonstrator. Depending on your driving style, there are a few other options.... Ian |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Hi Porny and thanks for the advice.
I think you have summed up my thoughts, it's the back that seems to roll more. I have been thinking about this for a while. I don't drive aggressively but i don't dawdle either. I think the springs, standard LR road springs, are probably fine for me as well so I think I will find a stiffer rear ARB and take your advice on the Super Pro bushes. Cheers BM52 |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 685 ![]() ![]() ![]() |
I have 28mm diam ARB and Koni raid shocks on back to reduce roll with camper on the back. All from Extreme 4x4. 130 Puma HCPU with an Artica 240LR Demountable Camper
epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Old thread resurrection:
Anyone recommend a uprated rear roll bar for a 110? I've seen the 28mm offerings from Terrafirma and Extreme 4x4x and wanted to hear people's experiences of them or if there are any others. |
No one use uprated roll bars
I have a 90 and bought an uprated rear ARB plus SuperPro bushes [from a D2 sponsor] and it has made a big difference. Corner with confidence, no issues off road and whent fitted with quality dampers [Koni for me] I think it makes sense. I do a lot of road miles from motorways to B roads and at all times the 90 feels planted and secure with some body roll but much improved from standard. BM52
Uprated as in 28mm??
Which make of bar did you buy? thanks |
From memory the bar was 25.4mm. BM52
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
I have got the biggest anti roll bar that Extream (Scorpion) do along with heavy duty springs the back end of my 90 does not move well planted, but remember it is fully loaded all the time. Also you have to change the bush mounting plates to accept larger bushes and bush retainers.
![]() Click image to enlarge If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Thanks.
Thats the one I want to get but Extreme have no stock till January. ![]() |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 784 ![]() ![]() ![]() |
What about the X-Eng X-deflex rear anti roll bar? Possibly the best of both worlds....
Rather expensive though
......true
But i have to spend my cash on something ![]() |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
I've now got a standard ARB on the front and Extreme 4x4 1" ARB on the rear.
Neither were fitted when I got the truck and the effect is greatly to reduce body roll, especially when overtaking when you can have relatively quick changes of direction. As I've said before, the torque settings for the three fixings make a huge difference to the ride. Per the Haynes manual (68, 40, 30 Nm?) is quite relaxed but do them all up f tight as did the bloke who changed my fuel pump, and it's almost undriveable. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
