Home > Technical > Parts swap over
Mblinko
France
Parts swap over
Hi
I'm going to be changing my v8 D1 for a 300tdi Defender quite soon. Will I be able to re-use the updated suspension and bumpers from my D1 on a Defender?
Post #285521 26th Nov 2013 10:24pm
grafty99
I think the suspension might fit Question bumpers is a no Sad 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #285526 26th Nov 2013 10:36pm
grafty99
just re read your post, is this v8 D1 to 300tdi D1?
I assumed you meant swapping to a 300tdi defender 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #285527 26th Nov 2013 10:37pm
Mblinko
France
No, my fault, I am considering a 300tdi Defender
Post #285528 26th Nov 2013 10:38pm
grafty99
ahh ok, well I believe my first post still stands then Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #285531 26th Nov 2013 10:43pm
Glynparry25
90 or 110/130?
90 and Discovery 1 have the same suspension setup so will be a straight swap Thumbs Up
If a 110 or 130, then you will have to get new rear suspension (the front is the same).
Bumpers- size wise it will be fine- but if you want to fit it you will have to change the brackets as the Defender mounts to the top/ bottom of the chassis rail where the discovery bolts through the sides (if that makes sense).
Glyn Dog Sheep
Post #285532 26th Nov 2013 10:45pm
The suspension may physically fit (a 90 - it won't fit a 110) but is unlikely to be the right spec. A Defender 90 is a lot lighter than a Disco. Darren
Post #285533 26th Nov 2013 10:46pm
Glynparry25
Defender 90 is only about 200Kg lighter than a Discovery 1 (depending on spec) due to it's heavy chassis which is one of the reasons why most off-roaders are built on Discovery/ RR chassis. 99% of the companies out there will sell the same kit for a 90 as Discovery 1.
Defender 90 workshop manual wrote:
EEC VEHICLE KERB WEIGHTS
Soft top:............................................................................ 1695 Kg
Pick-up: ............................................................................ 1694 Kg
Hard top: .......................................................................... 1746 Kg
Station wagon: ................................................................. 1793 Kg
Discovery workshop manual wrote:
VEHICLE WEIGHTS - V8i (3.9 full spec)
Front axle 970 kg ......................................................................... 970 kg
Rear axle 1010 kg .......................................................................... 1055 kg
Total 1980 kg
Glyn Dog Sheep
Post #285546 26th Nov 2013 11:06pm
200kgs is more than 10% of the vehicle weight, which sounds like a lot to me. Plus, most of that extra weight is over the back axle, so whilst the front might be ok, the back of a 90 would be very harsh on Disco 1 springs. It'd work, but wouldn't be my choice. Darren
Post #285571 27th Nov 2013 12:22am
Glynparry25
I agree with what you are saying but without knowing what springs are fitted to the Discovery you can't really decide (it might have soft off-road springs). I doubt it will make a huge difference, especially once you have added all recovery gear and any extras- tow hitch/ recovery points: 20-30Kg, full tank: 70-80Kg, recovery gear: 20-40Kg, water, spare fuel: 20Kg, gear, under vehicle protection.... you are straight away getting up to the same level as an empty Discovery.
I guess what I am saying is go for it- it takes about 1-2hrs to change a set of rear springs and shocks- Throw them on and then go from there.... if it is good then no money has been spent, rather than ordering a new set and then finding out the strength is about the same... Springs are also much more expensive outside UK.
Glyn Dog Sheep
Post #285577 27th Nov 2013 12:46am
