Home > Maintenance & Modifications > Question for those of you with RDX LED lights
For those of you with the RDX LED lights, what are you running in your side repeaters? Incandescent bulbs or LED also?
Just wondering as I thought the RDX relay was really meant for LED's but could handle both.
Would have thought the flash rate may be slightly different. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #285107 25th Nov 2013 3:39pm
K9F
Sorry Steve..... Bow down
http://www.google.co.uk/imgres?hl=en&b...1,s:0,i:84 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #285110 25th Nov 2013 3:45pm
munch90
on my old defender (led bulbs not rdx complete lights) I had to run incandescent bulb in repeater as with led in them all four flashed didn't matter which way you put indicators on put normal bulb in all worked
new defender rdx back and front led bulb repeater all ok
if led electronic flasher unit is used im sure flash rate is the same no matter what bulbs fitted .. but you got to be careful of wattage loading some flasher relays are quite low rated wattage ,some can only take one extra standard bulb (21w) for trailer lights etc
Post #285112 25th Nov 2013 3:50pm
smb
Running standard Incandescent bulbs in the side indicators with a full set of RDX Lights and no problem once you adjust the RDX relay.
Post #285114 25th Nov 2013 3:52pm
munch90
deleted
Post #285117 25th Nov 2013 3:57pm
munch90
is that the rdx flasher unit you adjust to get trailer dash light to work .. if it is how do you find the flash rate I found mine looked to slow so I put old led relay back and flash rate looked better
Post #285119 25th Nov 2013 3:59pm
smb
Yes, I purchased it as a whole kit from BoltonBits, but the full kit doesn't come with the side repeaters so I just left the originals in. I replaced the standard relay with the RDX one and turned the knob until the trailer warning light just went out.
I would say the flash rate is slightly faster than the standard. I have also tried it with both LED and Incandescent Light Boards on the trailer and no problem experienced, not even having to adjust the relay either.
The only problem I keep getting almost on a daily basis is because I went for an All Clear set, every time someone sees me reverse they come up and tell me I've only got one reversing light working. It's becoming a real PITA!!!
Post #285122 25th Nov 2013 4:14pm
munch90
just had to go and check what colour my fog is .. yes its clear but not had anyone say only one working never thought about it really .. mine puts worklight on as well to reverse
perhaps my rdx unit was dodgey (brand new ) as mine looked bit slow
not too worried about dash light as I got buzzer fitted for trailer indicators (I know you have to have one or the other )
the flash rate was within what its meant to be just didn't look right to me
Post #285124 25th Nov 2013 4:23pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
I have tried various different Led bulbs in my side repeaters but couldn`t get any that I was happy with,with regards to brightness and light spread. I ended up just keeping the original capless bulbs which I found the best at filling the lamp with light (as opposed to the led bulbs which only seemed to give a very small circle of light and were very hard to see in direct sunlight) I have the RDX lights fitted and have no issues with them or the flash rate of the supplied flasher unit. Smile
Post #285125 25th Nov 2013 4:23pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Having my first MOT in two weeks with the RDX lights. Hope it passes? BM52
Post #285126 25th Nov 2013 4:28pm
Mal - Your off your rocker Rolling with laughter Christmas booze started? Whistle Laughing
Thumbs Up
Back on topic, glad I started this thread. A good few answers here now as to thoughts on the set from RDX.
My main concerns really were trailer issues but it seems that is not s problem which is great. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #285127 25th Nov 2013 4:36pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Side repeaters are the originalS in mine and RDX LED elsewhere with no problems. Recently passed its MOT without any issues, so I wouldn't worry about the lights bm52. _______________________________
Puma Defender 90
Post #285131 25th Nov 2013 4:45pm
bm52
@nobby - that's good to hear Thumbs Up BM52
Post #285162 25th Nov 2013 6:23pm
GUM97
Anyone got any pictures of the RDX lights on the front? Thumbs Up An engine to TDi for!
Post #285204 25th Nov 2013 8:22pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Concur.
And mine has just passed its 2nd MOT with RDX lamps, no problem at all Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #285211 25th Nov 2013 8:40pm
