![]() | Home > Puma (Tdci) > Rear springs |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5813 ![]() ![]() |
They often look a bit arse down. Mine did so I put some Gwyn Lewis 1" spacers under the rear springs to get it all level, as I was happy with the ride, just not the look. Have got the spacers if you fancy fitting them, as I no longer use them.
Andy |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 ![]() ![]() ![]() |
Thanks Andy. I'm looking to fit a more HD spring as I can carry some weight at times. I was just surprised at how easy standard springs compress
Hd springs will cure the problem, but can be very harsh without load. I have no problem with truck being a bit bum down when loaded, but not whilst empty.
Andy |
