Home > Technical > Higher output windscreen washer pump?
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
Is there a higher output Td5 washer pump that is easy to fit? Have fitted an additional jet to the windscreen giving four jets but they are a bit weak. Cheers.
Post #280750 9th Nov 2013 12:46pm
Laurie
Find a headlight washer pump.
Post #280751 9th Nov 2013 12:48pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
what size pipe did youuse to big a diameter will give low pressure. 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #280768 9th Nov 2013 3:25pm
ickle
try wiring another standard universal washer pump in series in the line, should boost pressure and flow.
Keith
Post #280778 9th Nov 2013 3:52pm
chipmunk
Pipe diameter same as standard. Standard pump seemed weak just with two jets!! Will look into light washer pump. Thanks all.
Post #280779 9th Nov 2013 4:04pm
I've wondered the same thing. Fitted the twin nozzles to my 110. it's "OK", but just that. nothing mega.
Post #280796 9th Nov 2013 6:12pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
TD5 on washer pumps are available in a higher pressure variant, with a red top IIRC, used for the rear screen. I'm sure google will come up with the numbers. I have 2 red tops on my bottle and the pressure through 2 sets of jets is fine.
HTH
Post #280802 9th Nov 2013 6:53pm
Hello Mo, Long time no see!! Thumbs Up
Good tip that, I'll have a look and see what the number is.
Post #280820 9th Nov 2013 8:19pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
DMC100540 Thumbs Up Thumbs Up
Post #280836 9th Nov 2013 9:25pm
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Fit a Webasto Hotshot...
At aproximately GBP 60,- (on discount) you get hot water and higher pressure.
Q.
Post #283570 19th Nov 2013 10:05pm
dorstsmith2
fitted new red top pump Sunday works like jet wash now Thumbs Up
Post #283834 20th Nov 2013 9:00pm
Mo Murphy
Pleased to hear it Smile
Post #284080 21st Nov 2013 7:29pm
jimsadventure
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Q.
Where can you get them for £60 fella , i would be interested
Post #284698 24th Nov 2013 12:49am
ajps72
2001 Defender 110 Td5 SW Chawton White
Re: Higher output windscreen washer pump?
clean the check valve on the firewall Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #284704 24th Nov 2013 1:42am
