![]() | Home > Td5 > HELP needed headlight failure |
Yes, probably the switch melting because of too much amps going thru. Happens frequently, see my post earlier here. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
Hi Mark, Yes you are correct! Its a common Defender fault as the headlights are wired directly to the switch without the use of a relay so the switch eventually burning out is the end result. Once you replace the switch it might be worth modifying the headlight wiring to incorporate a relay to take the load off the switch to prevent it happening again in the future. Hope this helps!
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 ![]() ![]() ![]() |
Thanks guys all help appreciated, good excuse to tell work I've gotta go home before it gets dark.
epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Is this all defenders? Mine is a 2004 TD5
there was a link on the forum to a company who make a plug and play loom complete with relays for defenders ... WTF they don't fit them at standard I don't know but they are available for peeps who want a quick "proper" fix
Link for the relay loom here. Cheers, Vincent
cheers VeeTee
One of the first things that happened in my Defender ownership, the melting light switch - so one of my first mods, installing the relay loom along with a new switch.
![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Just been looking at new switches on fleabay, there are cheap switches at around a tenner and OEM at £25, does anyone know if there is actually any difference in quality between them.
Mark |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 ![]() ![]() |
Lucas is the one you need. Got mine from a seller called Adventure 4x4 on ebay. This was the best price I could find. About £22. I have seen reports of the ones in blue boxes lasting weeks before melting!
Will do the relay mod in the spring I think! |
