![]() | Home > Maintenance & Modifications > Noisy clutch when cold. |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
They all do that sir ! Td5s do this when cold it is the spigot bearing that the gearbox input shaft engages in in the end of the crankshaft,this dries out with age and causes the noise when cold it is not serious but is worth replacing the bearing if and when you need to replace the clutch or remove the gearbox for any other reason.
My Td5 has done this nearly all the time i have had it (3 1/2 yrs) and has got no worse during that time. 2005 Td5 90 XS Steve |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
A friend of mine has a TD5 Disco which does this, and I haven't been able to decide if it is the clutch release bearing, the spigot bearing in the centre of the flywheel, or the DMF itself. It has however been doing it for the last year-and-a-half and hasn't got any worse.
If you get to the bottom of this noise please do let us know! EDIT - cross post with Lou Sparts - interesting! There was a batch of TD5s built around 2002 which had defective spigot bushes fitted, they weren't properly oil-impregnated on manufacture (they're made of "Oilite", a porous broze alloy which is supposed to be oil impregnated and subsequently self-lubricating). My own Disco2 was one such, and now you mention it that shrieked when cold. A new bush was fitted under warranty and has been OK for 11 years and 200k miles since. |
abiffen90 Member Since: 14 Nov 2013 Location: Gloucestershire Posts: 17 ![]() ![]() ![]() |
I think its fair to see that land rovers as a whole do some funny things when cold. Thanks for your help guys. Very friendly forum, will be of great use to me. A warm welcome!
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
Nothing to worry about, my 2000 TD5 does this as too when the clutch is pressed. Stops after a minute of the engine being on
I don't think you should restrict it to "when cold" - they tend do funny (peculiar, not comic) things at any time. Temperament is part of their character, and the reason we love 'em so much. I keep telling myself this when mine randomly refuses to start! |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
welcome! Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
