Home > Maintenance & Modifications > D44 Cab Filter |
deep down Member Since: 02 May 2012 Location: France Posts: 204 |
After passing 2 weeks of following (not always following)other 4x4s' on dusty roads etc, the amount of dust entering the cab was too much to say the least. We came up with a temporary solution to reduce the dust, very basic, a piece of T Shirt under the air intake. Kind of worked.
So I've been searching the sites and came across the D44 Cab Filter, has any one tried it? Does it work? http://www.devon4x4.com/index.php?page=sho...;Itemid=14 Cheers |
16th May 2013 8:17pm |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
I have one which i use in the UAE desert and it is very good. I would suggest getting the pollen filter as well, as its a finer filter it keeps a lot more of the dust and sand out of the air in the cabin. Its a really good mod and in my opinion really worth the money.
Regards, Mark |
17th May 2013 5:54am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20347 |
How about fitting on top of the vent if you have chequer plate wing tops like mine does? $W33T $0U7H3RN $UG4R
17th May 2013 8:03am |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
The cab filter requires no drilling and is compatible with most chequer plate wing tops. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
17th May 2013 8:13am |
I assume it fits and seals around the same edge and diameter as the original? I just thought I'd ask as the CP obviously is proud of the actual wing and not flush. $W33T $0U7H3RN $UG4R
17th May 2013 8:15am |
Yes Steve it does. The bottom half bolts into e original holes, the filter then goes over the top and then the top half bolts onto the bottom half sandwiching the filter..
17th May 2013 1:12pm |
Thanks for the feedback, looks like something else on the purchase list for the next trip.
17th May 2013 1:25pm |
Fitted the cab filter yesterday, not really required in winter but ready for the next trip to Morocco.
It also comes with 4 extra filters in red, green, blue and yellow. There's no gasket with it which I would have expected and as I have the chequer plate I put a bead of gasket sealer around the edge of the mating plate. Click image to enlarge |
14th Nov 2013 7:37am |
