Home > Maintenance & Modifications > Headlights |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Could you give a link to those bulbs - I cannot find any E marked bulbs with that power output on the PIAA website. LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
13th Nov 2013 9:22pm |
Piaaonline.co.uk. Think this is different site to main piaa website .. Search on site h4
13th Nov 2013 9:40pm |
Well that site is at odds with the main PIAA site where these bulbs are NOT E Marked and for off-road use only.
http://www.piaa.co.uk/bulbs/bulbshow.asp?ID=halogen LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
13th Nov 2013 9:56pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
http://piaaonline.co.uk/index.php?route=pr...ct_id=1463
are these the ones? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Nov 2013 9:58pm |
@£36.56 EACH 2002 90 Td5 Station Wagon
13th Nov 2013 9:59pm |
I have emailed PIAA for clarification. LANDYWATCH
13th Nov 2013 10:05pm |
didn't mention any e marks on the website 2002 90 Td5 Station Wagon
13th Nov 2013 10:07pm |
PIAA H4 P43T 135/90W Bulb is E marked on the piaaonline site BUT on the piaa.co.uk site they are marked for OFF-ROAD use only. Same bulb, same cost.
Would be good if they were E marked LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
13th Nov 2013 10:17pm |
Yea I know .. When you asked I look at main site and found that too |
13th Nov 2013 10:19pm |
Anyone know why higher wattage h4 is not e marked ... Hid equipped car headlight is miles brighter than std wattage h4 so why can't we upgrade to brighter headlights (with wiring relay upgrade) as long as they set up right not to dazzle
13th Nov 2013 10:27pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
As a sort of sideways topic, what are the directional requirements for fitting driving/spot/auxilary lamps.
I want to fit my Lightforce 170s in place of the 55w generic pair I have fitted at present. What height & distance max should they be set to? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
13th Nov 2013 10:32pm |
There is no requirement for adjustment regarding additional driving lights as they are not illuminated with the dipped beam. They are ment to be adjusted for the best visibility on main beam which obviously you dip when there is a car oncoming 2002 90 Td5 Station Wagon
13th Nov 2013 11:09pm |
Thanks. I'll go to a straight level dark road & try them out. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
13th Nov 2013 11:16pm |
Confirmed by PIAA Sales, PIAA H4 P43T 135/90W Bulb IS NOT "E" marked. LANDYWATCH
15th Nov 2013 8:46pm |
