Home > Maintenance & Modifications > Headlights
Page 1 of 3 123>
Tom DCab
United Kingdom 2003 Defender 110 Td5 DCPU Oslo Blue
Headlights
Hi
i have been thinking about upgrading headlights on my 2003 110.
The existing lights are Wipac Quadoptic. Does anyone know if these are the standard lights or if they are an upgrade? I think the light output could be better.
can anyone advise on what units would provide better performance and would be an easy swap?
Tom
Post #281876 13th Nov 2013 3:59pm
grafty99
Wipac quadoptic are the standard units. I would recommend wipac crystal with osram nightbreakers as a cheap and effective upgrade Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #281877 13th Nov 2013 4:02pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Good thread here might be worth a read...
http://www.defender2.net/forum/topic24139.html?highlight=headlamp
cheers
simon
Post #281884 13th Nov 2013 4:16pm
Tom DCab
Thanks Guys, I am sure the LED's are amazing, but I dont have that sort of budget...unfortunately...
I think it will have to be the Wipac Crystals ones with the Nightbreaker bulbs....
Post #281906 13th Nov 2013 6:05pm
grafty99
I had wipac crystals and night breakers on my 90 before I got the LEDs, they were a huge improvement over standard. Now have the wipacs on my range rover classic so the difference in night driving between the classic and 90 isn't too much Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281911 13th Nov 2013 6:42pm
munch90
Just found some bulbs 135/90 watt e marked for European road use .. On piaa website
Are higher wattage allowed now as normal bulbs are 55/60 watt
They would be no good on standard wiring .
But are they for road use in uk ?
Post #281931 13th Nov 2013 7:29pm
grafty99
The headlight switch can melt and fail even with standard wattage so I would steer clear of these unless you do the relay mod Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281933 13th Nov 2013 7:31pm
macduff
I'm not sure the stock LR wiring is upto powering higher wattage bulbs. Though its nothing some relay controlled lamp feeds from the battery couldn't sort. I'm tempted to do this even with the stock wattage bulbs as I'm sure they dim slightly when I run the interior heater fan on 3. oops meant to quote the wattage post , some how I missed 2023 110 P400e
Post #281937 13th Nov 2013 7:38pm
munch90
Yes no good on standard switch or wiring
But are they legal ?
Max wattage was 55/60 I thought
But the new hid equipped cars are a lot brighter than you can get with 55/60 watt filament so are there new rules ?
Post #281940 13th Nov 2013 7:41pm
Tom DCab
The loom is sold by Devon 4x4...
http://www.devon4x4.com/index.php?page=sho...;Itemid=14
I am thinking that this could be a good option...?
Post #281942 13th Nov 2013 7:42pm
grafty99
The wipac crystals are so much more optically advanced that they would be an improvement over standard even with the original lamps. Changing the lamps to better quality, equal wattage ones (such as the nightbreakers) gives an improvement again Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281943 13th Nov 2013 7:44pm
munch90
They are brighter when relayed and heavier gauge wiring
Post #281944 13th Nov 2013 7:45pm
grafty99
^^ that'll do it Thumbs Up although to save the expense the difference a pair of wipac crystals and decent bulbs is so much you wouldn't need to bother with higher wattage bulbs Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281946 13th Nov 2013 7:46pm
leeds
Under Vehicle Lighting Regulations there is no maximum wattage requirement for headlights.
However to be road legal they have to be E marked.
Brendan
Post #281949 13th Nov 2013 7:49pm
munch90
Says e marked for european road use so guess that's ok then
Post #281950 13th Nov 2013 7:56pm
Page 1 of 3 123>
