Home > Wheels & Tyres > Wolf rims
Page 2 of 3 <123>
Byronavitch
England 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter(magic)
Post #280043 6th Nov 2013 2:39pm
The reason why many people opt for genuine Wolf steel rims is because at present they are the strongest standard LR rims for Defender, with a load rating of 2200kg per wheel, as compared to 1241 for the standard steel wheel (as used on 90s). I don't know the load rating for Boosts, I'm afraid.
Blindos are stronger still, hence their use on various heavy military specials.
There are non-genuine Wolf-style wheels available which are of vastly reduced quality and load rating. Caveat emptor!
Post #280050 6th Nov 2013 3:01pm
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I've seen a few variations on ebay while browsing ... if the time comes I'll bear that in mind. Thanks. 2009 110 XS Station Wagon
Post #280071 6th Nov 2013 3:49pm
Grouse
blackwolf wrote:
Defender "Wolf" steel wheels are 6.5" rims with a 20.6mm offset.
Defender Boost alloys are 7" rims with a 33mm offset.
These dimensions mean that the distance from the mounting face of the wheel to the inboard tyre seat will be:-
Wolf - 103mm
Boost - 122mm
And from the mounting face to the outboard tyre seat will be:-
Wolf - 62mm
Boost - 59 mm
(All dimensions rounded to nearest integer value mm).
So, approx 3/4" on the inside and 1/4" on the outside. which means that for the same tyre size, the Wolf rims should provide marginally more chassis clearance and better lock. Although technically it will "fill the arches" better it is debatable whether the 1/4" difference will be perceptible.
For reference, part nos for genuine Wolf rims are ANR5593 for the tube type and ANR4583 for the tubeless type.
Yes, that's correct for the difference to the tyre seat, but that doesn't give the total picture because a tyre seat closer to the offset does not mean that the tyre sticks out less, it merely means that the tyre wall is puckered in more, the width of the tyre will remain broadly the same - but the walls of the tyre will be distorted on the narrower rim - hope that makes sense - not easy to explain! In simple terms :-
Boost et33 7" wide
Modular et08 7" wide
Wolf et20.6 6.5" wide
thus :-
Modular sticks out 1" more than a boost, and
wolf offset sticks out 12.4mm or 1/2" more than boost
Assuming tyre width is the same mounted on different rims in simplistic terms the tyre width will remain the same - but the narrower rims will just give an inferior tyre wall profile
Post #280166 6th Nov 2013 9:04pm
Except that you really won't notice the difference when there's only 1/2" difference in rim width.
Post #280213 6th Nov 2013 10:25pm
Grouse
yes agreed,
I can though just tell the difference in offset just by looking, but many people wouldn't.
What it does show though is that you can get a better steering lock with Wolfs than Boosts Thumbs Up
Post #280286 7th Nov 2013 10:31am
timbar
Heh, I asked the dealer who sold us ours that very question and he said there was no difference; I thought there would be. What's the improvement in the turning circle? 2009 110 XS Station Wagon
Post #280296 7th Nov 2013 11:36am
Mountain_man
Wales
Nothing, unless you wind the steering stops in a bit.
The narrower rims and slightly wider offset mean you can increase the distance the wheels turn in without hitting the radius arms.
Post #280337 7th Nov 2013 2:04pm
Grouse
Enough to notice the difference! Thumbs Up A half inch greater offset, plus 1/2" less in rim width adds up. Tyre width remains more or less the same, it's the tyre wall profile that changes.
Post #280416 7th Nov 2013 8:22pm
keith
My wolfs recently purchased from BPman tubeless and painted in limestone . ( roof to match ) fitted to new MTRs 235/85 . Great on road manners with no turning circle difference .
Post #280423 7th Nov 2013 8:45pm
It's the same benefit you'd get if you fitted 19mm (3/4") spacers with Boosts - although of course you can't in fact get spacers that thin.
Post #280480 7th Nov 2013 10:55pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
BA and A-team t-shirt Rolling with laughter
Post #280528 8th Nov 2013 10:39am
Grouse
Does anybody have any good photo's of a Defender on Wolfs with 265/75/16's fitted please?
I know it's not recommended but many have done it without issue. The reason I ask is that I have a brand new set of Wolfs on 7.50's and am thinking of swopping over my 265 STT's - have tried the search function but pics have eluded me with tyres in this size on wolfs
Many thanks.
Post #280692 8th Nov 2013 10:36pm
jimbob7
FYI,Boosts are only about 900kg give or take a few,I only know coz I just fitted some and it's stamped on the back. Pov.spec,ftw. 2006, 110,TD5.
Post #280725 9th Nov 2013 9:01am
Not 265's, but 285/75 if that helps:
And 255/85's
Post #280741 9th Nov 2013 10:45am
Page 2 of 3 <123>
