Home > In Car Electronics > CB & aerial UPDATE now fitted :)
Page 1 of 4 1234>
Cheshire110
Wondering if anyone could recommend a CB radio for me?
It needs:
- to be small enough to mount INSIDE cubby box (can't measure right now but I'm assuming that DIN is ok for this)
- to have the channel controls/volume controls/squelch and readout and on the mic preferably so i can just have the MIC out of the cubby on greenlaning trips, and don't have to open up to change channels/squelch/vol
- some way of having a speaker outside the cubby, either by the mic having a decent one built in or by having the option of a small speaker mounted somewhere around the cubby.
Im not worried about paying a bit to get something that will last, but will only really need basic(ish) functionality so it doesn't have to be over the top. something simple, reliable and good quality will do.
cheers in advance guys, Cheers, David
Post #280112 6th Nov 2013 7:29pm
Cheshire110
also worth mentioning I've never owned/operated a CB before so it will need to be of 'universal' specification if that makes sense? just want it to work with what others are using on greenlaning etc Cheers, David
Post #280113 6th Nov 2013 7:31pm
Charliefox
United Kingdom 2013 Defender 110 Puma 2.2 XS DCPU Corris Grey
Hi David
Have a look at the "Polmar Venus" from www.thunderpole.co.uk
It should do everything you require Smile Chris
Post #280120 6th Nov 2013 7:55pm
Cheshire110
Yeah, looks very good thanks!
Stupid question but is the defender roof aluminum? No mag mount I guess - has to be gutter mounted? Cheers, David
Post #280126 6th Nov 2013 8:11pm
GUM97
Yep aluminium roof! Either gutter mount, or I've got a PSM-1 mount on the back Thumbs Up An engine to TDi for!
Post #280134 6th Nov 2013 8:34pm
If you have roof bars or rack they are even more ideal, my Mantec bars even have pre drilled mounting holes. WeWillWin🇬🇧🇺🇸
Post #280136 6th Nov 2013 8:39pm
jst
as above Tunderpole get my vote, they do complete packages i have the body side mount, works well at the rear of the vehicle. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #280147 6th Nov 2013 9:06pm
Charliefox
Just a thought David, but if this is for infrequent use over relatively short distances, a handheld may be a better option.
No installation hassle or aerial advertising expensive kit and far more secure.
Thunderpole sell Intek which aren't too bad - something to think about possibly? Chris
Post #280150 6th Nov 2013 9:16pm
Jim at www.4x4CB.com is an expert in Defender CB, check out his website.
At FCX we have a cubby box designed specifically to house a CB in the Defender
Post #280155 6th Nov 2013 9:34pm
Mdm
Another vote for Jim he off roads and like many good suppliers his advice is free.there plenty on his website explaining cb usage and how to get the best from one
Post #280178 6th Nov 2013 10:19pm
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
Another vote for Jim at 4x4CB.com that man knows more about CB's than the rest of us put together. His website is good but for real quality service give him a ring, explain what your looking for and he'll suggest something that'll work. He'll also be happy to go through all the mounting options. Personally a PSM-1 mount with a Springer on the back of a defender looks the dogs dangly bits. He also has guides on his website on how to sort out the SWR reading. 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #280215 6th Nov 2013 11:29pm
landy andy
Again Jim @ 4x4 cb Thumbs Up
But would advise against hand held, more costly, less good. Very disappointed in mine.
Andy
Post #280223 7th Nov 2013 12:17am
smb
Another +1 for Jim Thumbs Up Excellent Guy that gives plenty of 'correct' advice.
Post #280226 7th Nov 2013 12:30am
Cheshire110
Wow thanks for taking the time to give some great advice as usual guys,
I'll give both options a thorough looking through.
I did consider a handheld but I could do with all the range I can get as although I only Greenland infrequently, when I do it's usually as part of a larger group separated into 2/3 smaller groups, and because of where I live (Cheshire) it normally ends up in the north wales hills so any extra range is useful. Also it's another thing to forget/have cluttering up the dash.
I think a gutter mount is the best option for aerial for me, and I will just remove the aerial when I'm not using it probably, or look at a more 'temporary' mounting solution which can leave the aerial inside the car when not using it, but that will require some thought and a good look around the car tomorrow.
I think the polar Venus looks a good unit yeah, will have a look a Jim's site too now.
Thanks again folks Cheers, David
Post #280249 7th Nov 2013 8:25am
these are good, you mount the cb away somewhere and the display can be mounted on the dash, outside cubby or where ever you like
http://www.4x4cb.com/public/item.cfm?itemID=1725
Post #280253 7th Nov 2013 8:47am
Page 1 of 4 1234>
