Home > Technical > Tracker
Albert s
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Tracker
Can someone pm me re site internally to install tracker on 2009 puma 90
As I keep coming up with problems/ questions!
Post #278794 2nd Nov 2013 1:32pm
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
Sorry but I thought the point of a tracker was the install location and where the power feed excreta came from was random. Otherwise there would be no point having one Question
Post #279365 4th Nov 2013 2:23pm
Albert s
Yes that's true
Yes that's why I asked for help via Pm's
Confused
Post #279366 4th Nov 2013 2:28pm
Just choose a suitable power connection Not To Be Discussed In Public which needs to be a constant live not ignition live. I.e. Powered 24/7 not only on with the ignition / engine.
If you have problems discuss with Skytag direct OR an authorised seller / fitter. There are a couple on here such as Matt @FCX Chris at CSK land rovers.
You won't get anyone much "PM" you here as you are a relatively new user so we cannot tell who to trust. (Not intentionally intended to offend) Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #279406 4th Nov 2013 4:52pm
excossack
Take your time, sit in the car and go, if i was looking for a tracker to remove where would I look. Then think again, have brew and ponder the options. There are some cunning locations available but you just need to find them.
When a position is found, ponder the cable runs in your head and check for trim etc that can be used to hide the cables / make them look like they should be there. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #279438 4th Nov 2013 6:22pm
I responded to Albert's request shortly after he posted it Thumbs Up
Post #279503 4th Nov 2013 8:15pm
Porny
Site Sponsor
Just don't put it under the headlining - and use the interior light wiring like a lot of people seem to recommend.
The three stolen recovered Defenders I've help put right have always had the headlinings pulled down... so the thieves know this is a common place.
The other place I have seen them fitted is double sided taped to the 10AS alarm unit... which used to make me laugh as one way to steal a Defender is to swap the 10AS (and a few other things).
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #279647 5th Nov 2013 9:00am
excossack
Are you saying don't put it under the headlining (bad place in my book) and don't use the interior light as a source of power? 1999 Defender TD5 110
Regards
John M0VAZ
Post #279666 5th Nov 2013 10:16am
As has been said, you need to think like the thief.
Loom the power cable in to existing cables to disguise it.
It doesn't matter what source you use for the power because at the end of the day the thief can disconnect the vehicle battery (Skytags have their own built in battery to power them for 2 to 3 days)
Post #279667 5th Nov 2013 10:22am
Porny
Site Sponsor
Yes... the two 90's and 110 I've had after been stolen recovered (well, one was just attempted theft) had their headlining pulled down. I imagine that the thieves had found out this was a common place to fit trackers... both individuals and professional companies do it - as very easy to get the power feed.
In fact, at one point I seem to remember this was a recommended place by one of the tracker providers.
I fit insurance approved and none insurance approved trackers... and mine are not easy to find!!
In fact I go to great lengths to make any wiring mods look completely factory and do a proper stealth install.
Ian IRB
Post #279673 5th Nov 2013 10:44am
excossack
On speaking to suppliers of trackers at shows they suggested head lining or behind dash board...nah, to obvious! 1999 Defender TD5 110
Regards
John M0VAZ
Post #279676 5th Nov 2013 10:52am
Porny
Site Sponsor
Exactly...
They tell everyone that. So if you were a thief - where would you go and ask about the best position to fit the tracker???
Or is that just me being cynical.
Ian IRB
Post #279679 5th Nov 2013 10:58am
For a thief thinking and knowing where they are are two different things. Wink
It unlikely they will have enough time in my opinion to even look but that depends how quickly it's reported nicked. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #279683 5th Nov 2013 11:11am
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
That's why they jam them first of all, so they have a chance to get away and then have a root around.
You could consider fitting more than one Smile Jon - 110 td5 [sold]. Currently Defenderless.
Post #279710 5th Nov 2013 1:17pm
Yep more than one is an option, I notice on the Skytag leaflet that it is absolutely a no no that anyone takes pictures or such like or gives any specific technical detail. Let's just hope that it stays that way too.
Trouble is on here there is always one comment or two that gives hints to this and that of details on it, which any one with any brain at all can guess.
I agree with Matt on using the PM system and or e mail. Chillin In The BackwoodsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #279713 5th Nov 2013 1:26pm
