Home > Td5 > Lightforce 240 Hid's fitted...
Gareth
Thanks to forum member SMB, I now have a pair of LF 240 Hid to fit to my 90. It has the standard LR soft protection bar. Tonight, I started to work out how they would fit. I need to cut away the grill to allow the lights to sit back flush with the A Bar, but apart from that they will fit nicely.
One problem I have is that some of the captive nuts in the top of the A Bar have come out, and I need to glue some new ones back in. Its high density foam behind the rubber outer skin. Any ideas or repair procedures?
Also, is there anywhere that sells upgraded metal top A Bar brackets? the plastic ones are flimsy.
 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #278188 30th Oct 2013 11:41pm
Cheshire110
"the plastic ones are a bit flimsy"
i always have thought that the plastic ones are flimsy intentionally to prevent damaging the grille surround if 'nudging something'.. rather bend or break a clip than push backwards into the grille panel surround IMO
lights look good though! Cheers, David
Post #278192 30th Oct 2013 11:52pm
Gareth
Flimsy by design maybe, but I don't want any scumbag just ripping off my HID's, I would rather risk breaking the grill.
I just remembered that Craddocks list Mantec replacements, but I seem to recall they were not in stock a couple of years ago. Will try them again. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #278194 30th Oct 2013 11:57pm
Tiger
Mantec do a stainless bracket
Post #278210 31st Oct 2013 7:19am
Standard LF240's are fab those HiD's must be great Cool
The Hids I fitted to the 110 roof knocked the ipod out countless times so I changed to LED Thumbs Up
Post #278217 31st Oct 2013 7:33am
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
There were some for sale in the For Sale section a few days ago Thumbs Up It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #278218 31st Oct 2013 7:40am
Gareth
Got some Mantec brackets Thumbs Up
Very substantial. They are bare metal, so just putting some satin black on them before fitting. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #279619 5th Nov 2013 6:27am
jimbob7
Dude,beam shots at night are good,a long, dark, straight road with a marker in the distance is better. Thumbs Up Pov.spec,ftw. 2006, 110,TD5.
Post #279658 5th Nov 2013 9:37am
Gareth
Yes, will post the results. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #279661 5th Nov 2013 10:05am
familymad
They look like rabbit scarers!
#thebiggestlightsIcouldbuy
Rolling with laughter 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #279664 5th Nov 2013 10:11am
They remind me a bit of those daft exhausts - the size of dustbins - that the boy racers used to fit on their Corsas! Rolling with laughter
OK, I'm sorry, I'll stand in the naughty corner for an hour or so. Big Cry
Post #279685 5th Nov 2013 11:17am
K9F
Not HIDs but 240XGTs. I manufactured some brackets as seen in the picture that negates the requirement for cutting the grille. Plastic brackets still fitted, they do the job and have done for the last 5 years plus and they won't rot!
Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #279687 5th Nov 2013 11:30am
smb
Hi Gareth,
Good to meet you the other day and thanks for the deal on the lights. Have you set them up yet? Just a word of warning, as they are 50w HID XGT's do not stand in front of them to see how bright they are or you'll have white spots for days!!
Hope they are what you expected Thumbs Up
Post #279857 5th Nov 2013 9:11pm
Gareth
Yes, got them finally fitted last night. The Mantec top brackets are nice and strong, the grill was easy to cut with tin snips, and yes they are very bright indeed!
Hope to go out tonight and take some photo's. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #279954 6th Nov 2013 8:30am
