![]() | Home > In Car Electronics > Bolt on bits RDX LED lights...... |
3 Lions Member Since: 11 Jun 2011 Location: Geelong, Victoria Posts: 44 ![]() ![]() ![]() |
Has anyone here used these, the ones that look like standard Defender Rear lights, Not NAS lights.
Here they are: http://www.ebay.co.uk/itm/RDX-LED-Rear-Sto...4514wt_932 Col. ![]() 2006 Defender TD5 110. 2012 Trackabout CT. |
Ellisboy Member Since: 13 Oct 2013 Location: Deep South Posts: 539 ![]() ![]() |
I've fitted the front side light ones, and they're brighter than my headlights!
v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195 ![]() ![]() ![]() |
i have the full set of these seem very good value for money.
![]() s3 swb soft top |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 ![]() ![]() ![]() |
I've just fitted a Full set and they are very bright. A big improvement and very easy to swap
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
I fitted a full set recently and as others have said they are bright, well worth the money. _______________________________
Puma Defender 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Who actually makes them? I.e. Manufacturer. It's nice that you can buy them individually to spread the cost too. How are the clear ones no pink ish issues? Chillin In The Backwoodsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 ![]() ![]() ![]() |
Recently discussed here: http://www.defender2.net/forum/topic23973.html
Great upgrade, you won't be disappointed ![]() |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 262 ![]() ![]() ![]() |
Fitted them to the 300Tdi when I had it, was the first upgrade I did to the Puma. Great value and fitting is easy. 2008 Defender 110 XS CSW
Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
Thanks everyone...
![]() Looks like I will have to get some..... 1979 Series 3 109 FFR (ex Aust Army.) 2006 Defender TD5 110. 2012 Trackabout CT. |
Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487 ![]() ![]() ![]() |
I've got the full set and they're brilliant
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 ![]() ![]() ![]() |
Full set on mine
Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204 ![]() ![]() |
Full set on mine too and very happy with them, bright and better seals than the originals.
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
Ditto as everyone else I have a full set in clear very pleased
Trevor Wright Member Since: 11 May 2008 Location: Essex Posts: 87 ![]() ![]() ![]() |
For a 2008 TDCi 2.4 Puma, is fitting these RDX rear red stop/tail and white front sidelights simply a matter of unscrew, unplug, plug and rescrew - literally that, or is there some other little wrinkle to consider? Thanks for your advice. Trevor Wright '08 90 TDCi/TD4 XS SW |
