Home > Wheels & Tyres > Wobbly ZU/BFG AT combo
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
I thought that I had solved this problem but following some recent and rare motorway action the wobble was back.
This is a 2009 110 UTE with ZU alloys and BFG 265/75R16 AT fitted. I've had them balanced a couple of times, switched wheels around, etc etc. The video linked here shows where I suspect is the problem -its impossible to locate the wheels on the hubs in the same place twice.
Does anyone have any input on this?http://www.youtube.com/watch?v=fUpjez6Ca4k...share[url]
Post #279335 4th Nov 2013 12:17pm
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
I would say that the issue is you are never going to centre the wheel without some kind of spacer / shim. This is common with aftermarket wheels that don't have a spacer / shim to centre them. If you are lucky and get it centred a bump / pothole can then move it off centre thus it will then be out of balance.
Had this a few times on rally cars Wink
M
Post #279358 4th Nov 2013 1:59pm
macduff
Looks like the Zu wheel hub tolerances are a bit off. I think the oem boosts used a closer fit to the Hub centering the wheel as the oem tube nuts don't have a taper to help so their role is clamping not centering. It looks like Zu should have used taper style nuts if their hub tolerances didn't match oem, not that it helps you :/
It needs some sort of hubcentring ring to take up the tolerance, maybe a shim of stainless steel/similar might help take up the gap. I'd avoid a soft metal as it may get hammered out of shape if there was still some slack. 2023 110 P400e
Post #279362 4th Nov 2013 2:04pm
VeeTee
Netherlands
Do you use the conical wheel nuts?
http://www.defender2.net/forum/topic16983.html Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #279367 4th Nov 2013 2:29pm
sven
Norway 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Seems like he´s using the standard LR nuts for alloy wheel - take a look at the video.
Thinking of buying Zu´s for my 90, but this concerns me. 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition
Post #279807 5th Nov 2013 7:35pm
theorangebandit
that certainly is not a tight fit id send this information to the manufacturer perhaps find an outlet to approve your findings, it could be simply wrong nuts but im sure that advice would be splashed across the page when purchasing them. a shim, or collar to fit behind a spigot of sorts may be required[/code]
Post #279809 5th Nov 2013 7:40pm
VeeTee
Netherlands
I have the same combination, Zu + BFG265/75R16, for 4 years now, never had a problem with them. Cheers, Vincent
MySite
Post #279823 5th Nov 2013 8:15pm
jimbob7
Your wheel doesn't look like it's sitting flat against the hub, if the hole (center bore)on your wheel is to small,it's dangerous to drive.
If the wheel does sit perfectly flat against the hub you need a spacer in the center bore,either way its dangerous to drive as is. Pov.spec,ftw. 2006, 110,TD5.
Post #279848 5th Nov 2013 8:52pm
leeds
We have Zu Rims fitted to two of our Defenders with BFG AT 265/75 and BFG MT 255/85.
Have NOT experienced any problems with them.
Before blaming the wheels what about the nuts or studs? What were the nuts torqued up to?
Have any weights been shed so the wheel/tyre combination is out of Balance?
Brendan
Post #279852 5th Nov 2013 9:01pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
+ 1 to what Brendan says.
I have exactly the same issue with std boosts and 235/85R16 tires (GG, BFG AT, COOPER STT)
Bolts are orig LR items that came with the car.
I took of my spacers, suspecting them, no difference so guess studs can be ruled out.
Only when putting the wheels on by hand and taking care about centering before tightening up i am vibration free.
If i just tighten them up, or the tire service... vibration.
Post #279854 5th Nov 2013 9:08pm
munch90
I found I had bit of play between wheel and hub too but not as bad as in video .
I had some wheel nuts made (only 3) look bit like std nut but instead of flat washer that tightens on to wheel they have taper so they line up wheel on the wheel nut hole outer edge .. I put the three in just nip them up to hold wheel central then put std two in and tighten up then remove tapered and fit other three std nuts
Post #280300 7th Nov 2013 11:42am
caribcat
Yes, as mentioned in previous post I used the wheel nut that came with the vehicle from the factory. It's an XS and came with Boosts
Post #280575 8th Nov 2013 3:29pm
caribcat
Great plan. I'll try that.
Post #280577 8th Nov 2013 3:35pm
caribcat
Brendan
Torgued to 130. all weights present and correct!
Post #280578 8th Nov 2013 3:36pm
nickhodgson
Hi
Are your swivel pre-loads correct? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #280971 10th Nov 2013 2:36pm
