Home > Maintenance & Modifications > Winch battery connection |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20479 |
Mobile centre can probably help you on this or possibly Matt @FCX. Sorry I can't help you on any more than that. No Guts, No Glory.
3rd Nov 2013 6:27pm |
Specialbikejames Member Since: 03 Mar 2013 Location: Bristol Posts: 47 |
eBay or Vehicle wiring products will sell lengths cut to size with ends crimped.
http://www.ebay.co.uk/itm/BLACK-BATTERY-PO...460e8ac2b7 35mm2 cable will be fine. |
3rd Nov 2013 6:33pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
If you let me know via pm what length cable and terminals you require the chances are that I can help you out.
Brendan |
3rd Nov 2013 6:43pm |
Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245 |
Thanks for your help and offers....i think i have one from e bay. 50mm should be thick enough...? I hope! Only twelve quid..
3rd Nov 2013 10:05pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8094 |
35mm2 as James put above you will need with the appropriate fittings, if you dont have the proper crimper you can join them with pliers and a hammer! not the best but will suffice.
35mm2 is ideal for single motor applications upto 6hp ish, after that you may want to upgrade wire size, 70mm2 for twin motors is the norm on 12v. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
3rd Nov 2013 10:18pm |
