Home > Maintenance & Modifications > Winch battery connection
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
So....winch is installed along with cables back to the battery. Black on, red to isolator....however, i now need 8 inches or so of more red and some connectors to do the final connnect from the other side of the isolator to the battery. Where can i get the right cable (britpart 12000 lb) and a couple of connectors. No one seems to sell connectors big enough. What rated cable do i need...thanks.!,
Post #279164 3rd Nov 2013 6:25pm
Mobile centre can probably help you on this or possibly Matt @FCX. Sorry I can't help you on any more than that. No Guts, No Glory.
Post #279165 3rd Nov 2013 6:27pm
Specialbikejames
United Kingdom 1998 Defender 90 300 Tdi HT Rioja Red
eBay or Vehicle wiring products will sell lengths cut to size with ends crimped.
http://www.ebay.co.uk/itm/BLACK-BATTERY-PO...460e8ac2b7
35mm2 cable will be fine.
Post #279166 3rd Nov 2013 6:33pm
leeds
If you let me know via pm what length cable and terminals you require the chances are that I can help you out.
Brendan
Post #279171 3rd Nov 2013 6:43pm
Jonno1968
Thanks for your help and offers....i think i have one from e bay. 50mm should be thick enough...? I hope! Only twelve quid.. Very Happy
Post #279237 3rd Nov 2013 10:05pm
jst
35mm2 as James put above you will need with the appropriate fittings, if you dont have the proper crimper you can join them with pliers and a hammer! not the best but will suffice.
35mm2 is ideal for single motor applications upto 6hp ish, after that you may want to upgrade wire size, 70mm2 for twin motors is the norm on 12v. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #279241 3rd Nov 2013 10:18pm
