![]() | Home > Puma (Tdci) > Traditional or Clear LEDs |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
I plan on changing my brake/sidelight and indicator lamps to LED ( OEM size NOT NAS ) but I'm not sure if ALL clear or traditional red/clear/amber would look best on my 2010MY 90 XS in Santorni Black.
Any thoughts??? ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
clear on the front and coloured on the back looks good to me
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
+1
![]() ONLY ACCURATE GUNS ARE INTERESTING |
CEEGEE Member Since: 02 Oct 2013 Location: Yorkshire Posts: 135 ![]() ![]() ![]() |
+ 1
A question. When travelling abroad you have to carry spare bulbs. But if all side/brake/indicator lamps are LED???
I suppose only individual LEDs are likely to fail and not the whole light set at once unless there is an electrical fault which would also fail a normal incandescent fitting anyway ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
I was going to go clear all round, however an now also bit concerned about the saxo look. I'll need to find some pics. 2008 Defender 110 XS SW - M57N2 / 6HP28X
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
I thought Saxo, so went clear front, coloured rear, as was with XS trim.
Andy |
Found one (picture) .. I don't think this looks too 'Saxo' .. going to go clear.
![]() 2008 Defender 110 XS SW - M57N2 / 6HP28X |
Does look better on black.
![]() Andy |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
Personally it had to be clear front, colour rear Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
I solved that problem by wrapping 1 side light and 1 tail light in a cloth and stored them in the battery box, just in case. along with a light switch and under the drivers seat I have a spare serpentine belt....just in case BM52 |
Guess the plod can not require us to carry complete replacement LED lamps with us, just in case of failure which is less likely to happen than with single filament bulbs. I have only the center brake lamp and the front indicators left with filament bulbs, so maybe should buy spares for those. Although with a SVX front and with an A-bar, there is no way that I would even try to change the bulb of my front indicators somewhere on the road. I would not have the tools with me, nor the desire to dismantle half the front of the truck. ![]() When LED lamps with multiple LEDs fail, indeed it starts with playing up, meaning individual LEDs are going, but not the entire unit. At least that is what happened with my SVX tail lamps as you can see below. All replaced now with new ones from Mobilecentre.... Eric ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
![]() Click image to enlarge ![]() Personally I used to like the clear front and rear but since changed my mind. Each to their own I say, if I had to choose the clear all around it would have to be the SVX type like Eric has but they are much more expensive. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
I had clear all round but swapped them for LED in traditional colours. Each to their own but my preference is the traditional route on this occasion. _______________________________
Puma Defender 90 |
