Home > Puma (Tdci) > EGR replacement
IanW
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zambezi Silver
EGR replacement
My 2008 Puma CSW is showing the classic EGR type problems. For what it's worth, if anyone needs a replacement the cheapest I found was at M J Fews ebay shop. Genuine parts including gaskets at £135 which was the cheapest I found anywhere. The quote for fitting was about £120. The indie in Bristol who usually mends it quoted £370 all in. So financially a no brainer - booked in at M J Fews (Charfield, Glos, main dealer) next week. Vehicle 5 and a half years old and 31k miles. MJF said this was common at that sort of age, but from posts on this Forum they seem to break for a past time anyway. One wife - livid
Post #276926 26th Oct 2013 2:29pm
I have done my own, also cleared the codes and had no issues since last year. Cost me £0 except parts. Your parts prices are indeed correct though, they went up last autumn before they were about £118. $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #276960 26th Oct 2013 4:16pm
Dieselhead
Just brought an EGR & gaskets from LR for £130inc Vat
I know the lads in the parts dept & I get good discount when I haggle Whistle
Thought I had a prob, but seems ok at the min. So its been added to my own parts dept Laughing
I do all my own work so labour costs me £0 Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #276983 26th Oct 2013 6:09pm
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
i had the same, light came on, brought the part then light went off about 2 weeks later and been running it fine for 8 months without replacement
Post #278743 2nd Nov 2013 9:18am
IanW
EGR replaced
EGR bought from MJF ebay shop and fitted at a cost of £42 by them on Wednesday and vehicle now appears fine. They agreed that the EGR was the problem and thus didn't connect it to the computer. So total cost was £147 which we were quite happy with. One wife - livid
Post #278764 2nd Nov 2013 10:50am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
What symptoms did you have? 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #278766 2nd Nov 2013 10:55am
IanW
Normal acceleration when cold, very flat spot at 2k revs and a reluctance to go beyond it when hot, no self cleaning noise when switching off.
MIL warning light not on when symptoms first developed, then came on about half way through a six mile journey. Light off all the way en route to the dealer, although self cleaning process still not happening. Back to normal completely after the work was done. One wife - livid
Post #278781 2nd Nov 2013 12:37pm
carrotbay
Sounds familiar!! Going to try and fix with disabling the egr through a remap first .. Otherwise a new egr. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #278788 2nd Nov 2013 1:06pm
When mine had problems it was producing stuck closed codes which is fine by basically self blanking BUT it would of course produce the MIL so had to be replaced. Being stuck open is much more of a problem though by far. $W33T $0U7H3RN $UG4R
Post #278793 2nd Nov 2013 1:21pm
carrotbay
Replaced it today. I'm sure the skin missing from my knuckles will grow back soon Thumbs Up 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #282513 15th Nov 2013 7:19pm
A sod to do ain't it ! I expect you've noticed the difference in performance already though. Thumbs Up $W33T $0U7H3RN $UG4R
Post #282517 15th Nov 2013 7:28pm
carrotbay
Yes .. Better in a straight line, but have a problem with a loss of performance when coming out of a corner .. Almost a misfire .. Any ideas?
http://www.defender2.net/forum/topic24587.html 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #282534 15th Nov 2013 8:40pm
IanW
Flat Spo
To add to my original post - the flat spot returned although the egr was doing what it should. Back to MJF yesterday, and a problem with the wiring harness on top of the engine. Replaced, and all seems well. A weak point with the original they said, and the replacement has some sort of mod apparently. Hopefully that's it! One wife - livid
Post #282619 16th Nov 2013 9:08am
Dieselhead
Well the EGR which I brought for my truck was fitted today. But not on mine as its OK for now
Mate brought his 09 puma over for 90k service & each time the engine was switched off it sounded like a distressed phesent Laughing What a squeel!
This is now the 2nd egr I have fitted to this engine & did it in less than 1 hour Cool as I knew what to do
All nice & quite again now Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #282923 17th Nov 2013 5:08pm
