![]() | Home > Maintenance & Modifications > Winches |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
What's the relative merits of the low-line or bridge versions? One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
some like the bridge version so they dont have to worry about mounting the solenoid pack elsewhere. Some non bridge ones come with the pack mounted above the motor some have them loose. with a non bridge version you get good visibility of the rope going onto the drum which is ideal if you are running wire and dont want to snag it. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
yes i said that because i use simex extreme trekkers and i havnt got stuck yet with them
am i not trying hard enuff ? yes i do have a front winch though and normally your probly pullling yourself out the way you came in rather than pulling yourself further into the sh*t ? 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Simex extreme trekkers
Sounds like a TDS 12.0i is the right choice:
12k lbs of pulling power is well over-spec'd and won't strain the winch under pretty much any circumstances (ideal for a bogged down and laden 110 or 130); pretty cheap (429 + VAT) allow you to add a synthetic rope without breaking the bank; good performance in crap conditions. Oh well, I'll add it to the list ![]() + New Defender 110 First Edition |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
For self recovery leisure use, its got to be a TDS Goldfish,, Good winch and excellent valve,, forget a 8274 for that job
Have a overvolted TDS sat in the middle of the challenge truck, been more reliable that the Twin GP 8274 ![]() Main Brian James Trailer Dealer for South West UK |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Im with AndrewS on this one
