![]() | Home > Puma (Tdci) > Leak!! |
H4mmy90 Member Since: 21 Apr 2013 Location: Taunton Posts: 81 ![]() ![]() |
Sorry pics gone to my gallery
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Martyn Member Since: 10 Feb 2011 Location: Stourbridge, West Midlands Posts: 151 ![]() ![]() ![]() |
More than likely the foam seal under the windscreen and / or the D brackets either end of the windscreen. Either way, sounds like the dealers black mastic gun will be coming out
![]() A common problem I'm afraid. ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
I had a very similar leak. Again only when parked on a slope. The dealer fixed it by a bead of silicone in the join between the windscreen and bulkhead. BM52
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Mine was the front window which needed to come out and be resealed 1951 80" S1 2.0
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Thats the reason why the rubber mats have a lip round the edge ! 2005 Td5 90 XS
Steve |
It works! 1951 80" S1 2.0
The dealers said they need it for a week!! So hope They'll sort it
It would be nice if after 65 years of building them they could have sorted it out at the production stage instead of having to inconvenience their customers. 2005 Td5 90 XS
Steve |
Gleaney Member Since: 03 Dec 2012 Location: Earth! Posts: 94 ![]() ![]() ![]() |
I had the same problem on my 60 plate Defender and I lost count of how many times it went back to Land Rover. They sealed every hole on the front but the water was coming in between the screen and the rubber ( where the glass sits against the rubber ) Once they sealed this it's been fine.
http://www.zee-rover.nl/downloads/water-ingress-manual.pdf
A bit of light bed time reading ![]() |
Great so it could be loads of things!!!!! Hope the dealer covers all possibilities or this could drag out!! Hope lucks on my side
https://www.defender2.net/gallery/albums/u...cedure.pdf
Sorry this is a better one. |
On mine water ran off the gutter, back along the underside of the gutter and underneath the door seal (at the top of the door)then dripped onto the door glass, I used a blob of sealant on the underside of the roof gutter right on the edge, to create a "drip groove",only get water in when I'm using the hose pipe.
A drip groove fer those who dunt no wot one is \/\/\/ ![]() Click image to enlarge |
greenoval25 Member Since: 12 Apr 2013 Location: Essex Posts: 37 ![]() ![]() |
I have also got a similar leak on my 13plate 2.2.
I also get puddles in the rear on top of the wheel arches but only after heavy rain. I have not had time to get it back to the dealers yet, I do sometimes wonder if I would be better off sorting these problems out myself! Kev |
