Home > Td5 > Wipers
Jack77
United Kingdom 2006 Defender 110 Td5 XS CSW Epsom Green
Wipers
Ok, just arrived and already annoying .... but please help
Don't know if this is the right place to post this
I have this problem with the wipers : 3 positions - 2 of them same speed and action , i.e First down does the same of First up.
Any idea where to look at ?
Post #276629 25th Oct 2013 4:50pm
jimbob7
Possibly wiper motor park switch (common fault, £25 from LR),do the wipers sometimes stop mid-screen?
Post #276650 25th Oct 2013 5:43pm
Jack77
Indeed they do!!
Post #276680 25th Oct 2013 7:11pm
jaketravels
United Kingdom 2002 Defender 110 Td5 HT Chawton White
It does sound like the park switch, my first 90 did the same.
Post #276689 25th Oct 2013 7:35pm
mk1collector
Only buy genuine park switches.
Post #276709 25th Oct 2013 8:23pm
landy andy
Easy job unless you've got air con. But as mentioned original part only. Very basic job.
Andy
Post #276713 25th Oct 2013 8:31pm
Jack77
Changed the wiper motor once on my Series , quite easily (rust apart)
Here I have air con Big Cry
Will pop in LR tomorrow morning to see if it's available !
Post #276719 25th Oct 2013 8:44pm
geobloke
Do not worry. Even with A?C it is not difficult. I have just been through the entire wiper system replacing the wheel boxes, rack, gears, arms, spigot and park switch. All of it can be done without touching the A/C, only the centre dash, dash top and bits behind need to be moved.
Incidentally doing this has revolutionised the vehicle, best wipers I have ever had on a Defender. They do 90 degrees no more no less... Thumbs Up
Post #276985 26th Oct 2013 7:19pm
Jack77
Ok, you have convinced me! Next Saturday will be the day!
Post #277243 27th Oct 2013 5:59pm
