Home > Td5 > Wipers |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Possibly wiper motor park switch (common fault, £25 from LR),do the wipers sometimes stop mid-screen?
25th Oct 2013 4:43pm |
Jack77 Member Since: 13 Oct 2013 Location: London-Hertfordshire Posts: 56 |
Indeed they do!!
25th Oct 2013 6:11pm |
jaketravels Member Since: 12 Feb 2012 Location: Cheshire Posts: 39 |
It does sound like the park switch, my first 90 did the same.
25th Oct 2013 6:35pm |
Only buy genuine park switches.
25th Oct 2013 7:23pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5657 |
Easy job unless you've got air con. But as mentioned original part only. Very basic job.
Andy |
25th Oct 2013 7:31pm |
Changed the wiper motor once on my Series , quite easily (rust apart) Here I have air con Will pop in LR tomorrow morning to see if it's available ! |
25th Oct 2013 7:44pm |
Do not worry. Even with A?C it is not difficult. I have just been through the entire wiper system replacing the wheel boxes, rack, gears, arms, spigot and park switch. All of it can be done without touching the A/C, only the centre dash, dash top and bits behind need to be moved.
Incidentally doing this has revolutionised the vehicle, best wipers I have ever had on a Defender. They do 90 degrees no more no less... |
26th Oct 2013 6:19pm |
Ok, you have convinced me! Next Saturday will be the day!
27th Oct 2013 4:59pm |
