![]() | Home > In Car Electronics > The Kenwood KVT-526 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20751 ![]() ![]() |
The KVT-526 is back again after a long time being out of stock on justkenwood.co.uk. Price is very very good too, especially being brand new. A year or two ago these were retailing for £300 - £420
Very easy fit in the Defender as there is no additional modules as standard, remove old HU fit single DIN cage check and fit wiring and slot in. Job done. ![]() Link here, KVT-526 WeWillWin🇬🇧🇺🇸 ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1438 ![]() ![]() ![]() |
Just a shameless plug
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
yeah, and doesn't even have BT as standard... looks ok but not exactly mind blowing.
personally i don't think they work in defenders because they cover switches, clock and air vents but looks a pretty good option for other vehicles/base spec ones -quality will be good. ill stick with my parrot asteroid.. BT, 3x USB, handsfree dialling which works perfectly, iPod in, aux in, internet enabled etc etc etc Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
I have a similar one from 'another manufacturer' , the format does work in a Defender, the clock/vents are not covered - granted there are a few switches covered but I have found that's its only ones I don't use that often and more often than not if I have the radio on the screen is closed.
That one is a good price, although if you factor in £399 for sat nav, £99.99 for bluetooth, £29.95 - £34.95 for a cable to connect an iPod/phone ![]() I didn't want to connect and power a load of extra boxes which ruled out the Kenwood and Alpine offerings, which didn't leave much else. I'm sure its a good unit and if you already have a sat nav then its a bargain ![]() dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8220 ![]() ![]() ![]() |
Right then, firstly i know nothing about ICE systems.
i would like a unit that does DVDs/BT/Sat Nav/CDs and radio to fit in single DIN for Puma Fold up screen i am happy with. Does this unit do all that? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
BT and satnav would require extra (not cheap!) modules Cheers, David
So any suggestions as to what unit would do all that.
considering either a stand along Garman (prob) sat nav system and new stereo or something that does the whole lot. open to any suggestions. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 ![]() ![]() ![]() |
Very good price. It's a great sounding system. Screen doesn't really get in the way in day to day use.
The map updates for the sat-nav bit are a bit of a pain though. You can get the lifetime upgrades from Garmin quite cheaply for their own devices, but not for the Garmin/Kenwood sat-navs... Seems a new SD card at £100ish for each upgrade is the only option available. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Had no problems with a "Flip Screen" unit in a defender,,
The Kenwood looks very good value in bog form !! Ran a Pioneer in the first couple, that got swap from one to the other,, another new updated one in the current 110, Phone, DVD, Nav, I pod USB etc etc
Sure you have seen mine ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
What phone do you have?
I have an iphone 5 and use the TOMTOM app, around £45 for the whole of Western Europe or £30 ish for just the UK & Ireland one. Better than standalone IMO because maps update for free, it's easy to use, can grab addresses from contacts on your phone, google maps etc. Also available on android etc I use a parrot asteroid classic Single Din unit in the car because I can stream bluetooth, use their (by far the best) bluetooth hands free - hand on heart never got a name / number wrong, as well as all the usual stuff (& Internet connectivity) They're not 'cheap' but not expensive either. Around £250-280 but I'm not sure if they're still making them. Shops may still sell them or ebay, if not: They do a selection of 'add-on kits' some of which are now touch screen and support the tomtom app (a lot run android) and I've had car kits before off them which were v good. Parrot.com/uk Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
The BT module for the Kenwood is £99 but allows music streaming, phone book available on screen and text messages. (Depends on phone and HU combination)
Sat nav module however is expensive at £399 hence why I use a garmin stand alone sat nav. Easier to update and cheaper too. Having said this the Kenwood 2 DIN HU's have all this included in one unit however the price does reflect this in all the models. I like the 526 because you get your base HU in and then you can add to it what you want when you want it. There has been comments made about them not being able to stand up to Defender ruggedness and terrain vibration abuse etc, none of this is true! They are surprisingly strong regardless of make IMO. (Premium range at least) Kenwood are OE in high end Mitsubishi cars / 4x4s. WeWillWin🇬🇧🇺🇸 ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
James, I would personally would settle for a decent DAB head unit with Bluetooth, and then buy an Ipad. Fitted Sat-Nav is old technology. It is also very one dimensional. The Kenwood sat nav is a £399 option - same price as the Ipad, but the Ipad will do so much more, If noting else the screen is bigger an so much clearer. Although I have no experience with it myself, there are several members using various apps to map routes (memory map?). Landy Andy I think is in the process of setting it up in his new double cab. Saw it on his thread about Tallon socket. Might be worth a PM
Agree with Jim above, I have the Wifi ipad only myself but the cellular version also has GPS too, but the catch is you need a contract to use it and thus you guessed it, more money! Saying that if you have the wifi only ipad as I have you can still use mapping apps in the same way you would a paper copy. Just a digitalised form, much easier IMO.
I like the Ram mount on the passenger grab handle it looks good there and really secure. Not quite sure how I'll get on with three screens though. ![]() ![]() ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
