Home > Maintenance & Modifications > Shelf for cargo area of 110? |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
Higgers, did you have any problems getting that shelf in one piece? You cannot teach stupid people to do clever things
17th Mar 2010 10:24am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
I wondered that as well
17th Mar 2010 10:30am |
Higgers Member Since: 08 Apr 2009 Location: Cheshire Posts: 668 |
The measurements (51 inches) is the largest diagonal of the rear door, lower left to top right because of the rear door hinge. This will allow you to slide it straight in. You'll just need to drop the seat backs. The 51 inches also fits nicely between the rear seat belt brackets, thus it doesn't slip about.
You can then get plastic under bed boxes from cheapo shops for about £3. Regards the carpet, I didn't staple it down because the dogs will only f*ck it up and i therefore wanted the option to throw it out and replace when it starts to stink. Hope this helps. |
17th Mar 2010 10:47am |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 |
Fitted the mantec loadguard and shelf(ves) there are 2. They both go at the same hight but you could have just half the shelf space. Damn I never feel like people will understand what I write
Anyway some pics. Hope they help to explore the options. Click image to enlarge Click image to enlarge Worth mentioning as it is design, on a 2 piece OEM cargo barrier the knurled nut to release the lower panel is inacessable and the shelves will not fit unless the knob is removed. Click image to enlarge Click image to enlarge Fixings for mounting to the wheel boxes are not included but will need 16 nuts and bolts 6mm and 32 washers and 16 holes drilled. I am waiting till monday for that. Easier in the wharehouse and drier Click image to enlarge Hopefully you can see the holes in the 2 preceding shots. Some trimming of the carpet will be required for a good finish and I have noticed a lot of damp under the carpets which will need investigating, I may actually take it to the dealers before I drill holes so they cannot blame me. It is quite robust freestanding and I have secured it to itself with straps and bungees, rattle testing will be conducted tomorow :D Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
20th Mar 2010 3:59pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
That Mantec one looks awesome! I might need something more temporary, though - Higgers, I was thinking a ply sheet would be the option so great to see yours.
Cibit - I too have had damp carpets in the rear (underneath my rubber load bay mat) although I reckon it is condensation. Higgers - I know what you mean about the design of the components. I've got Mantec internal window guards and they make fitting the cargo barrier a real pain (even more than it is normally!). On a side note, after taking the cargo barrier out a couple of times to fit large loads in, the really soft allen-key bolts completely rounded off. I've had to buy a set of M8 steel bolts to replace them (highly recommended). One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
20th Mar 2010 9:44pm |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
like those...
can i ask what the height is to the underneath of the shelves, and the depth (front to back) of each of the shelves? ta |
22nd Mar 2010 5:10pm |
Height is 17.5 inches Depth/shelf =18" Overall depth 36" sorry for imperial but could only find a wooden ruler circa 1896 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
22nd Mar 2010 5:40pm |
THF Member Since: 18 Jul 2012 Location: Sunny N Hants or Pompey Posts: 83 |
Guys, sorry to hijack the thread, looking at locally fabricating the stowage cage on the side of my 110's load bay, but need the thickness of the lip (in which the shelf sits on). Can anyone help out with the measurements. My divers eye has it at about 12mm, am I close?
Thanks on advance, THF! |
17th Aug 2014 10:57am |
