Home > Technical > 2008 2.4d 90 pick up immobiliser |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
anyone know.
20th Oct 2013 7:31pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5662 |
Would think it will have, and is a standard item.
Do you have any dash warning lights? Andy |
20th Oct 2013 7:43pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Try Topix. Free to register. Then enter full vehicle VIN number and you will get the build profile of that particular vehicle.
http://topix.landrover.jlrext.com/topix/vehicle/lookupForm LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
20th Oct 2013 7:47pm |
Thanks for that will try
20th Oct 2013 8:34pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 806 |
Fitted as standard (i.e. alarm unit a.k.a 10AS unit) - but probably not active if poverty spec.
Easily done with the correct diagnostic equipment... can even wire in the ultra sonic sensor etc. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
22nd Oct 2013 10:01am |
Thanks Ian for the reply.
the dealers are fitting one this week as not insured without. I would of thought everything had an immobiliser as standard the last ten years steve e |
22nd Oct 2013 1:06pm |
All Puma's have the alarm/immobiliser unit, so unless your insurance needs a CAT 1 it is already there...
All you need to pay for it to have the settings changed, fobs/programming and a reluctor ring fitted if needed... and then up to you if you want the ultra sonic sensor. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
22nd Oct 2013 2:59pm |
Thanks For the info Ian
22nd Oct 2013 3:03pm |
