Home > Technical > Transmission/Gearbox Rattle
Page 1 of 3 123>
CFB
Another issue has developed, not sure what it is.
When I roll to a stop and depress the clutch I hear a rattling/chattering sound, seems to come from the gearbox or transmission somewhere in the middle of the car but it is getting worse all the time. Stops as the car comes to rest.
Anyone any idea what it could be be before i go to the dealers again? Andy
Post #2719 14th Jul 2008 9:11pm
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
my one as been taken away due to gearbox rattle and clutch problems
has been inspected by a land rover uk manager and the dealer is now removing the gear box and clutch
and rocker cover gasket front hub seals for repairs or replacement
dan
Post #2734 15th Jul 2008 3:20pm
CFB
Weird thing is today there isn't a sound from the gearbox Confused Only occured after a long motorway run yesterday, guess it is one of those unexplained ones.
It has however developed a really annoying vibrating noise though, sounds like an exhaust knocking or similar, occurs when under load and lowish revs.
Can't decide if it is a problem or just noisy transmission etc which is part of the cars character. Andy
Post #2735 15th Jul 2008 4:03pm
Daniel TD5
it will only get worst
try the follow stick in low range and let it crawl along if it sound like a tin of spanners its had it
my dealer stated not a problem at all sir land rover uk said it need the gearbox out and the clutch. then sort the noise out i do think this is the second gearbox as the dealer let slip we did change the gearbox in decmber
will keep you posted
dan
Post #2737 15th Jul 2008 4:44pm
CFB
Is yours a Puma or a TD5 Dan? Andy
Post #2738 15th Jul 2008 5:07pm
Daniel TD5
my one was one of the first batch of 07 its a TDCi XS Double Cab its been a bit of a pain from the start
but it is having big gearbox clutch issues about every 6 months. i have a very high clutch use drive to work throught the blackwall tunnel each day
did you not reject your last one with gear box issues
dan
Post #2741 15th Jul 2008 6:12pm
mse
Check the rear diff and shafts Wink really do Mike
Post #2746 15th Jul 2008 6:26pm
Fatboy Slim
Wales
If it makes anyone feel better:
Rejected an 07 110 due to numerous driveline probs, egr probs, oil leaks, missing bolts and rivets, inoperative wipers Shocked (Never wired in-not picked up on PDI Shocked ) etc etc
Replaced with a D3:
3 Clutches, 19 EPB disasters (in 3K)
Replaced by.......................
Good old fasioned Td5!!!!!!
Probs to date???
Ashtray full, needs a wash Rolling with laughter
Trust me.......It could be worse Thumbs Up
Post #2749 15th Jul 2008 6:45pm
CFB
Yes I did and I don't want to go down that road again but with a dodgy roof and now noisy transmission.............. Big Cry Andy
Post #2751 15th Jul 2008 7:06pm
Daniel TD5
sound like same old same again
saying that my td5 55 plate xs double cab was top glass only a few minor problems in 38 thousand miles in 18 months
puma Big Cry
saying that i have a 57 plate gs d3 no loan from the dealer at present and its got les spec than my puma work that out
what happend to the d3 s with harden kakem xenons heated seats cost cutting again Whistle
dan
Post #2754 15th Jul 2008 8:12pm
CFB
What exactly am I checking/looking for??? Andy
Post #2755 15th Jul 2008 8:15pm
mse
The play, noise and whine Mike
Post #2759 15th Jul 2008 10:58pm
sib
I`m having the same problem with my 130 Puma. Didn`t have this with the 90 Puma though.
It occurred firstly for a few minutes at a time on a motorway run and now happens more frequently, often when going downhill.
It was worst with full weight in the back going downhill the other day, approx 35mph - 45mph on the gearbox and braking lightly there was so much chatter that I had to stop. It is the same clunky noise as you get from the gearbox/clutch area when you stall the car from first gear. We have tested to see if the handbrake was slightly sticking on but didn`t solve it. My car is definately worse affected when it has weight in the back, not sure why this would be ...
Taking it to dealer next week who reckons new clutch may be needed but they haven`t done full assessment yet.. Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #2767 16th Jul 2008 7:06pm
Daniel TD5
updated friday by the dealer
looks like its getting a recon gearbox this week could be a new clutch as well
seems land rover are now refurbing large parts like gear boxes and such like to send back out to dealers
will get it back thursday i hope
daniel
Post #2830 21st Jul 2008 2:26pm
CFB
Mine's gone in today, noise getting worse. Service guy mentioned a sticking handbrake as a possible source of the issue. Andy
Post #2831 21st Jul 2008 3:08pm
Page 1 of 3 123>
