Home > Technical > Top 5 WINTER preperation Must do's |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2760 |
Sorry to sound naďve but what exactly is the problem you guys are trying to solve with the fuel filler caps? Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
19th Oct 2013 8:51am |
When on the plains or on a green lane, the caps can get a fair bit of muck around them, a defendoor just keeps the cr@p out of the lock. In arctic conditions, keeping an oily rag over the top of the filler cap, keeps the lock working, and you have a rag to wipe your hands with
19th Oct 2013 9:33am |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
Only recurrent problems I have in cold weather are the door locks freezing (I have to go through the safari door & squirm onto the front seat) & the handbrake taking time to unfreeze once I get the engine running. With the latter problem, would an X-Engineering handbrake disc be less likely to freeze-seize, or more? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
19th Oct 2013 1:45pm |
Door locks........spray them with a silicon lubricant or such other
Handbrake...........leave it off but in a low gear. |
19th Oct 2013 2:08pm |
