Home > Puma (Tdci) > Rough Idle
schuee
Rough Idle
Evening,
Have experienced today, though only when hot when coming to a standstill, that the engine is idling slightly rough, the rev counter is going up and down, not enough to stall, though when I give it some power the engine briefly makes a clacking sound and then all seems to be fine for a while.
It has done it a few times today, and to be honest the engine has sounded like it is clacking more than it used to do, could it be the sign of a faulty injector? Also not sure if it is related, I did hear the EGR valve chatter whilst driving the other day, and when I turn off the ignition, on the odd occasion the EGR sounds squeeky whilst performing its cleaning cycle.
Any information would be appreciated before I go and see my dealer.
Cheers All
Keith
Post #274641 17th Oct 2013 8:30pm
Cheshire110
my defender has had a couple of 'fixes' done on the EGR, symptoms were v similar to yours (not so much clatter, but hunting revs)
all sorted seemingly easily on warranty and been ok since second time *touch wood* Cheers, David
Post #274648 17th Oct 2013 8:45pm
schuee
Hello David,
Hopefully its nothing too serious, it has been running as sweet as a nut, I suppose it has to throw a wobbly ever now and again Laughing
Will call my dealer, they are always really helpful in sorting things out.
Keith
Post #274744 18th Oct 2013 8:33am
Cheshire110
Yeah it wasn't much serious I don't think when mine was done (assuming it's similar/same problem)...
A new gasket or valve or ECU update or something (or combination thereof) fixed it if I remember, all covered by extended warranty Cheers, David
Post #274751 18th Oct 2013 9:05am
x-isle
Definitely sounds like a sticking EGR to me, I had pretty much the same as you when my EGR started to go.
Easy swap out but some of the nuts are difficult to get at. What you don't want is the EGR sticking open as it'll stall at idle and be almost impossible to restart.
When mine started to play up, it did stall and wouldn't restart for a while. I guess that it unstuck itself and closed which meant it started, then when I rev'd the throttle you could hear the valve opening and closing but is was very noisy. You could even hear it when driving. Then the self clean just became very loud.
Swapped it out and it transformed the performance too, so it was probably pretty sooted up. I've still got the one I removed and when I get a chance I will strip it an clean it out. I'll keep it as a spare. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #274752 18th Oct 2013 9:12am
Interestingly mine did exactly the same thing last Saturday at the end of a long run, and it has the EGR deactivated in s/w.
Post #274768 18th Oct 2013 11:16am
x-isle
Usually, an EGR issue causes an airleak (when it's stuck open). Therefore, the sympton could be air leaking from anywhere. Craig Rogers
2007 Puma 110 XS
Post #274794 18th Oct 2013 12:26pm
Caterham
He's a bit more thought....
My map sensor manifold (If that's the right description - the tube that holds the map sensor) Is leaking slightly. How much of a leak would it take to throw the calibration out and sound clattery?
Not easy to quantify i'm sure. Would it have to be very significant or could just a slight leak cause it?
Many thanks.
Post #490175 9th Jan 2016 9:04am
