Home > Maintenance & Modifications > Modular wheels query |
McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686 |
Hi all,
I'm after a second set of steel wheels to put my Simex JT's on and modulars seem to fit the bill. I run mach 5's as my daily wheels and the 3" offset gives me plenty of steering lock even with 285's on. So, the question is, where can I get some mod's with 3" offset (16x8). My normal supplier is drawing a blank at the moment, anyone any thoughts? Cheers, Ross The Scotia Winch Challenge |
18th Mar 2010 9:21pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
McS I use this guy next day delivery very helpfull
http://stores.shop.ebay.co.uk/JCS-4x4-Whee...QQ_armrsZ1 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
18th Mar 2010 10:10pm |
McS,
Fekete must have close to a 3" offset on his. I run on Mach 5s too. If you compare pictures between Fekete and mine bear in mind his tyres are 12.50 and mine 11.50 width, but can't be far off! Fekete's Modulars. My Mach 5s: If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
19th Mar 2010 7:38am |
Hello Fekete,
Never one to miss an opportunity to post a piccy or two. You too don't half have some cr4p in your album. I had a bit of a clearout. Off to crewroom for cup o' tea. Only you and me on-line at the mo! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
19th Mar 2010 7:42am |
Got to do a bit today so catch you later have a good day...I've got to empty mine out too NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
19th Mar 2010 7:45am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2443 |
4" backspace (0 offset) is the right choice on 8" wide wheels. Any other would cause you troubles. I have 285`s also. Mine were imported from the states though. Puma 110" SW ............................................................. Earth first. Other planets later |
19th Mar 2010 10:43am |
Have you considered upping the width to 10"? Didn't read the original post thoroughly, sorry!
Mine and Fekete's are both 10s. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
19th Mar 2010 11:20am |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
Going to the show this weekend, will see what wheels are on offer
Funds are saying modulars at the moment |
19th Mar 2010 12:17pm |
