![]() | Home > Puma (Tdci) > Air intake issues |
SGoggin Member Since: 04 Jul 2009 Location: Australia Posts: 19 ![]() |
I had a similar issue on my old 2.4 - although it did not sound like a V8 or I would have left it as is!
On mine the EGR started sticking, when the EGR is open the noise level increased dramatically especially when idling. The other issue I had - but this was in my new Defender is that the intake itself was loose - still is - and is vibrating nastily. |
obsidian Member Since: 08 Oct 2013 Location: Glasgow Posts: 6 ![]() ![]() ![]() |
It's interesting that you say you think your intake is loose as that's the feeling I have with mine. My 110 is only 2 years old and I have covered 23K in that time and it has only just started to get very throaty at around 2000rpm. I see that others have said that the 2.4 is throaty but that has not been my experience until recently so for me I can't say that it is a normal noise. It is going into the dealer next week and this is on the 'to do' list but in my experience the dealerships don't have as much mechanical experience these days so my expectation for them diagnosing it is low. Hence asking around the forum.
Thanks for your response |
john_g Member Since: 12 Oct 2013 Location: Leeds Posts: 5 ![]() ![]() ![]() |
Mine is a 2.2 not a 2.4, but from new there was a blarting farting noise from the engine air intake. This was not so obvious with the side window closed, but with it open when driving around town the noise was a definite irritant. It was cured by fitting a raised air intake - this also stopped (I hope) the ingestion of fine road spray and mist into the air filter along with the induction air. The air filter has a foam sheet to trap ingested moisture, but on one occasion before the raised intake was fitted the filter became so clogged with moisture that the suction from the turbocharger collapsed the intake pipe causing a throaty roar and a reduction in engine power. Was this the source of your roar, I wonder?
John. |
