Home > Maintenance & Modifications > LED bulbs
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
LED bulbs
There are various bulbs available on e-bay which would appear to be a direct replacement for the filament types fitted to my 110 puma. Are there any issues with these bulbs and the ECU?, as far as I can see the only "sophisticated" lights are the internal lights with their delayed turn off and turn off after several minutes if you have the doors open. If there was to be an issue I suppose the "canbus" type may work? Has anyone any experience of either type of bulb?
Thanks,
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #272360 8th Oct 2013 6:31pm
GUM97
Don't rink there's any problems with LED bulbs at all. Chris @ CSK Land Rovers (site sponsor here) sells LEDs, so may be worth seeing what he can do for you rather than ebay Thumbs Up An engine to TDi for!
Post #272377 8th Oct 2013 7:03pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Hi Chris, No issues with fitting Led Bulbs as they will work fine. However as I am sure someone else will be along in a minute to point out ,Led bulbs in a standard Land Rover light fitting are illegal as the light is only E marked for a normal filament bulb. Not sure how bothered you are about that as most people agree that an LED Bulb is a worthwhile upgrade and most sellers do sell a lot of them! Laughing
Post #272379 8th Oct 2013 7:04pm
leeds
First issue?
What you are proposing is illegal
Obligatory lights have to be type approved, for that read E mark these days.
I general terms the obligatory lights fitted by Land Rover are type approved for filament bulbs
Replace a filament bulb with the appropriate filament bulb is legal.
Replace the filament bulb with an LED then the type approval is invalid and the light is illegal
Replacing the filament light fitting in its entirity with a correct type approved E marked LED assembly then that is legal.
Have had some experience with these e bay LED previously and their longevity was not what they claimed!
You may experience problems with the flash rate on the indicators.
After the Peterborough show someone phoned me up complaining that the set of Leds he bought was not working correctly. I quickly informed him he had not bought them from us, chances are that he would need a load ballast or loading module.
Brendan
Post #272384 8th Oct 2013 7:12pm
ChrisCM
Hi Guys,
Thanks for your input, I take your point about the illegality of the bulbs Brendan but the reason I was looking at these comes down to cost, I don't think I can justify the cost of a full replacement light set. Do the interior lights have to be e-marked as well? as this is probably where the best power savings can be achieved when camping.
Post #272399 8th Oct 2013 7:48pm
leeds
Chris, I do not think that interior lights are obligatory lights, therefore type approval etc is not a legal requirement so changing them is not an issue.
If you require lights for camping then LED is the way to go to save battery power.
For external camping lights, no e mark required but I would suggest one or two with a decent IP rating (Ingress Protection) of 67
However I would suggest you do not go for massive light output say about 1,000 lumens but with a decent flood pattern. You would only need a 5-10 metre range not half a mile.
Brendan
Post #272406 8th Oct 2013 8:10pm
ChrisCM
Hi Brendan,
Thanks for the info re interior lights.
I agree about the camping lights, there are currently 2 "worklights" fitted to the rear of my roofrack, really I think they are just cheap spotlights, the beam pattern is pretty useless and I do intend to change these for LED floodlights to give more coverage.
Post #272427 8th Oct 2013 9:22pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
For rear work lights I would recommend the VisionX LEDs wot Brendan sells. We have 2 on the back of my 90 for camping etc- not cheap but they are bright enough without being too dazzley and very neat and tidy shape.
[/img] Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #272449 8th Oct 2013 10:46pm
Rigid Industry dually's are pretty good too, for work lights, available in flood or spot patterns (or one of each)
Post #272461 9th Oct 2013 6:32am
ChrisCM
Hi Pam,
Wow, those are small, what's the wattage?
Post #272543 9th Oct 2013 12:05pm
Pam W
No idea on the technicals but the factor with LEDs seems to be to do with lumens rather than watts.
Details here http://4x4overlander.com/lights/visionx-led-lights.html Our blog - http://landytravels.com/
Post #272552 9th Oct 2013 12:29pm
BigWheels
A general point to be aware of is that illegal fittings may affect warranty of other parts, but most importantly insurance validity. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #272558 9th Oct 2013 12:53pm
leeds
Chris, the Vision X light uses a 10 watt LED and is rated at 900 lumens.
Wattage of any light has little to do with light output which is the important part of a light.
The Vision X light draws about 0.8 amps and has a calculated raw lumen output of 900 lumens.
Brendan
Post #272662 9th Oct 2013 8:18pm
ChrisCM
Thanks Brendan,
I wanted to know the wattage to work out the current draw to see how they compared to the 2 lights which are currently fitted to my Landrover 2x55w, approx 8 amps, so 10 times as much as 1 Vision X !
Post #272700 9th Oct 2013 10:15pm
