Home > Technical > last minute fault |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6294 |
hi all,
not sure of the best way to approach this. I'm absolutely sure I have a problem with either my MAP or MAF sensor. car is in tomorrow for MOT and would like to get these checked / swapped under warranty. the problem I've got is both intermittent and not massive but clearly getting these swapped under warranty is favourable to paying out of my own pocket. any suggestions. should there be fault codes logged that would indicate a problem? I have absolutely no doubt that I'll be told everything is fine but after 3 years of high / lows I'm pretty sure everything its quite right....in terms of nuts and bolts I'm absolutely sure everything is right but something electrical / electronic isn't . ultimately I'm getting them swapped but if something isn't right then it SHOULD get sorted underwarranty its just I have little faith in the dealers......unless something has completely stopped working they don't seem too interested in fixing? thank you |
6th Oct 2013 9:37pm |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 443 |
what engine is it?
6th Oct 2013 10:14pm |
tdci 2.4
6th Oct 2013 10:16pm |
Aaaaaarrrggghhh I'm sorry but as suggested many many times before, you need to find a good Indy or someone who knows your model of defender and get them to check it over
Sorry I don't know the answer to your question |
6th Oct 2013 10:22pm |
There's alot to be said for going to the dealer.
They have the properly trained people and the right equipment. They diagnosed a duff MAP on my Td5 within a few minutes. I guess they might want a bit more of a specific idea as to whats wrong mind. Dave |
6th Oct 2013 10:27pm |
well its not the usual dealer tomorrow.....so just maybe they'll sort it.
I'll let you know. I've thought about getting one of the code readers |
6th Oct 2013 10:58pm |
intermittent problems are a pain in the backside and it's like going to the dentist. It never hurts when you go!
A standalone diagnostic tool can be run in the vehicle was you are driving so would make things easier to spot Dave |
6th Oct 2013 11:00pm |
well its past its MOT however they've picked up some probelms and will tell me all about them when I collect....
I'm all excited now as I can't wait to find out what the problem has been all along...... may be I should be perhaps they haven't found the problem I've been trying to solve and have found all sorts of other isses |
7th Oct 2013 1:13pm |
I think you are of a too nervous disposition for Land Rover ownership.....
7th Oct 2013 2:03pm |
You are possibly right ?
Anyhow first class customer care was received today. Passed the not as expected but its also been booked in for a return visit. New bumper, new rear prop, new breather pipe, replacement harness for the central locking rear door and a check / diagnostics on the map and maf. |
7th Oct 2013 5:19pm |
