Home > Group Buys > 3rd run group buy for the integrated remote key |
Kyulandy Member Since: 16 Nov 2012 Location: Frankfurt/Main Posts: 1 |
Grazie Daniele!!!!!!!!!
Key works perfect. Bye Bye Ingo |
8th Mar 2013 3:31pm |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 |
Done mine. All good. The range is twice as great too.
9th Mar 2013 7:26am |
Egghead Member Since: 25 Nov 2012 Location: Surrey Posts: 255 |
I want one of these!
14th Mar 2013 9:51am |
comandante Member Since: 29 Oct 2012 Location: at home Posts: 3 |
Hello Daniele,
thanks for your effort. After copying the key by the key service and coded by Nanocom, the indicator light flashed twice during unlocking and 4-times during locking, which is one time too much and indicates a weak battery. I measured the battery with 2.84 Volts and replaced it with an identical (CR1220) one. I placed the new battery positive pole upwards in. Now neither the red lamp works while pressing a button nor am I able to lock or unlock. By the way I measured the new battery with 3.23 Volt. What do I need to do now and why is the battery in a new key already low or empty? Must the red light in the key iluminated, if I press a button? Kind regards Comandante |
15th Mar 2013 6:40pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
Mine does this too, didn't realise it meant the battery was weak! |
15th Mar 2013 8:35pm |
wrong! when the battery is low the lights not flashed at all..... pag. 33 user manual (UK) Mine fob (2 years old)have this sequence also (indicator light flashed twice during unlocking and 4-times during locking) With "my" keyfob and certains AS10 SW version work like wrote but it is normal! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
15th Mar 2013 10:53pm |
Thanks Daniele, thought it was ok as the range is much better than the old original one.
16th Mar 2013 8:22am |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Anyone have one of these using on a 2.2 ? Key works but only once to restart vehicle after stopping I have to lock vehicle with fob unlock then it will work ?
22nd Apr 2013 11:07am |
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 |
My 2.2 2013 refused the pod! It was not possible to pair the key with my car using the pod. Today I visited my dealer - after 15 min work everything works fine. No problem for my dealer to learn the new key to my car. Cheers Det locker bleiben |
22nd Apr 2013 2:54pm |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 |
Late 2012, with 13 plate updates already in it and has had no issues. Just plugged the pod in, left it and then the key worked. No issues at all and a great integrated key ===================================
Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
22nd Apr 2013 3:38pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
I'd like one of these too!
Sounds great. |
18th Jun 2013 2:14pm |
Johnnyb0 Member Since: 26 Jun 2013 Location: Ulster Posts: 45 |
I'd like one of these too, please is this still possible?
21st Jul 2013 9:18pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Is one of these any good on my 1998 td5, I have an nnn000120 ecu, what is it capable of? Can I immobilise?
JD 2008 TDCi 2.4 XS CSW |
21st Jul 2013 10:13pm |
S92 Member Since: 03 Oct 2013 Location: United Kingdom Posts: 2 |
Is it still possible to purchase 2 keys and a programmer?
6th Oct 2013 8:56pm |
