Home > Maintenance & Modifications > How to prevent mudflaps cracking?
shaggydog
Hello All,
Suppose it fits here.... as it is maintenence and requires modification.
Has anyone found a way of having mud flaps for more than a year before they crack, split and die?
Mine have done just so on the rear so have spent out on a new pair Rolling Eyes
From what I can see, they fatigue where the support bracket ends, any thaughts?
Thank you in advance!
Dog
Post #271213 3rd Oct 2013 6:27pm
grafty99
My thoughts are that there could be a fluid leak of some kind? Spraying onto the mud flaps and causing them to perish. the ones on my 52 plate are original, as are the ones on my dads 1996 110 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #271214 3rd Oct 2013 6:40pm
GUM97
I've never known them to crack before! An engine to TDi for!
Post #271231 3rd Oct 2013 7:30pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
My 2009 mudflaps have lasted amazingly well. The way i have achieved such success is too remove them and leave them in the garage. They still look like new! Rolling with laughter
Post #271234 3rd Oct 2013 7:35pm
shaggydog
HA Love It.
I currently have one in my footwell and one just about hanging on.
It's weird it seams to be just where the bracket ends, they crack and have split.
Will take a picture tomorrow in the daylight.
Can safely say there is nothing in that area leaking to effect them.
Only rears on a 110 if that makes any difference?
Post #271237 3rd Oct 2013 7:48pm
Green Machine
When mine went I cut the bottom couple of inches off the old ones and used them as reinforcement at the 'hinge' on the new ones - they've been on about a year and all good so far! Also used some big stainless repair washers when I bolted them on to the brackets to try to stop them flexing as much. I've got some pics somewhere if anyone's interested. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #271246 3rd Oct 2013 8:15pm
smb
Do you tow anything like a caravan or box trailer? If so, the vortex created could be making them flap back and too and if dry they will eventually deteriorate. Or, have you had them bottom out in any ruts, stones, kerbs, etc.....
Can't think of any other reason unless they were cheap plastic ones put on by dealer instead of original LR ones!
Post #271248 3rd Oct 2013 8:17pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Original LR mudflaps - 4 yrs old and 40,000 miles. Still good, no cracks, but this is on a 90. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #271251 3rd Oct 2013 8:23pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
I'd had a set of Britpart ones put on when Matthew at Tayside Landrover did my chassis refurb in May. Matthew has offered to replace them free of charge for a pair of new Landrover ones.
Now that's good customer relations Thumbs Up
I think they burst because they were plastic rather than rubber?
DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #271253 3rd Oct 2013 8:28pm
shaggydog
No havnt been towing anything like that.
Not bottomed out since I gave it the lift.
They have no markings on them though so suspect them not to be genine.
@Green Machine I like the idea of cutting the bottom inch off and using as reinforcements, though I'm not sure how the chevrons moulded in would effect it?
Post #271254 3rd Oct 2013 8:32pm
JWL
The fronts went on mine a couple of years ago but the backs are just over 11 years old and still good. I do seem to catch the fronts more and the backs will seem to flex the mounting backet more so that's probably why they've lasted longer.
Post #271257 3rd Oct 2013 8:47pm
mk1collector
Do you mean the actual mud flap cracking or the rear 1/4 panel it bolts too?
Post #271270 3rd Oct 2013 9:21pm
shaggydog
@mk1collector: The actual mudflap rubber has cracked and failed.
Post #271272 3rd Oct 2013 9:32pm
mk1collector
Never had it myself Whistle
Post #271273 3rd Oct 2013 9:41pm
Laurie
Before you fit new flaps hammer a radius into the lower edge of the metal support by clamping it in a vice with a length of round steel rod and bending paer way round the rod - about 45 degrees.
Post #271288 3rd Oct 2013 11:59pm
