Home > Puma (Tdci) > LED headlights into SVX/X-Tech headlights
Page 1 of 3 123>
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
I'm going to fit LED headlights shortly,the phase 7 Trucklite model to my X-Tech but I'm not totally sure about the wiring as the headlights run a seperate high/low light set up.Do I need to rewire the loom to join both H/L together into the one light and if so can I fit a set of driving lights into the Halogen high beam light spot?.I'm after some idea's as to what is the best option on my vehicle. Thanks Pat
Post #268031 20th Sep 2013 7:10am
geobloke
I have not come across the Truck lite headlights before, but they are tasty... and very cheap to buy in the US, circa $200 each...
http://betterautomotivelighting.files.word...698449.jpg
Wonder if they are E-marked...
Post #268066 20th Sep 2013 9:55am
PAT303
They are designed for the Jeep wrangler and also fit the VW Beetle,the new model. Pat
Post #268073 20th Sep 2013 10:19am
nakatanenga
Germany
They are not E-marked and not suitable for RHD.
They have no positioning light, so they are not recommended for SVX and similar
And yes they are cheap but unfortunately cheap made as well, i had them in my hands. WANTED:
SII or SIII in max 1.5k
Post #268092 20th Sep 2013 11:03am
geobloke
Well there you go then...
Post #268326 21st Sep 2013 1:37pm
They don't need to be e-marked for Australia do they ?
other than those, there are JW Speakers and Noldens
Post #268367 21st Sep 2013 6:26pm
dgardel
Italy
http://www.defender2.net/forum/topic15159.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #268390 21st Sep 2013 7:43pm
leeds
For Australia the lights would have to meet ADR (Australian Design Rules) requirements
Would E marks satisfy ADR? Have no idea, but am hazarding a guess and say probably yes.
Have had a quick look at the Truck Lite specifications for their light. What I noticed is that the Truck Lite website did not appear to give a figure for the light output. This I find odd as the most important information you require for a driving light is light output.
What they do state
Quote:
When properly mounted, exceeds FMVSS-108 and CMVSS-108 DOT requirements for low beam and high beam performance
Now reading US DOT rules does not exactly make exciting reading. However they do give a figure in candela as a minimum and maximum value.
Brendan
Post #268392 21st Sep 2013 7:44pm
PAT303
I don't know what E marked means,so no I don't think we have that in Oz. Pat
Post #268515 22nd Sep 2013 10:32am
PAT303
What they do state
They can't be worse than the originals. Pat
Brendan
Post #268517 22nd Sep 2013 10:33am
TJ101
But even if they are expensive in price, don't mean you can rely on them being any better in quality Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #268526 22nd Sep 2013 11:06am
They are E marked according to MudStuff's web site and £595.00 for a pair Thumbs Up
"EU approved Truck-Lite 7in LED Headlamps" and have front position lamp so OK for SVX
http://www.mudstuff.co.uk/trucklite-phase-7-led-headlamps.html
Post #271099 3rd Oct 2013 6:50am
leeds
We know and deal with both Peter at Nakatanenga and Kevin at Mud.
Mud have not had LED headlights on their website for some time now.
When Peter made his comment about Truck Lites not being E marked as a commercially available unit that was correct.
Mud have only very recently put LED headlights back on their website and I quote
Quote:
MUD-UK is pleased to announce it has the secured the very first batch of EU approved Truck-lite Phase 7 LED headlamps to hit the UK.
In fact these lights are probably extremely new as I can not find mention of them as E marked on the American or EU version of the Truck Lite website!
Maybe I should call in and have a cup of tea with Kevin as he is not a million miles away from us. I do know he has a few new products in the pipeline Thumbs Up
Brendan
Post #271113 3rd Oct 2013 9:01am
leeds
Me and my bad habit!
Thought I had been cured Razz
Brendan
Post #271115 3rd Oct 2013 9:02am
SteveG
2005 Defender 90 Td5 CSW Belize Green
Seeing as the comment was only made on 20th September, I suspect it's more accurate to say that he assumed he was correct in stating that they are not emarked and not suitable for SVX etc.
There are a number of tests of these lights with speaker etc in the US. In almost all the tests the speaker units come out on top for light performance. However, I'm not sure they would recommend selecting them if there was a £/€350 difference as there is here in Europe if you buy a set.
As for quality, there is no question that Soeaker use top quality led's, however, as Tim has pointed out having the headlamp unit corrode within 12 months of use in a number of cases, does make you question again whether these are worth a 60% premium if bought in Europe.
Post #271119 3rd Oct 2013 9:21am
Page 1 of 3 123>
