![]() | Home > Maintenance & Modifications > Radio & centre dash removal guide (picture heavy) |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
Great Job !
Excellent very useful ! Thanks Steve ![]() Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20754 ![]() ![]() |
Thank-you for the kind words. Sadly I think you are that bit too far away for me to do it for you.
![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
TUT, TUT, Steve, lose the negative attitude.
Your response should be more proactive and helpful. Something along the lines that you will be more then happy to assist Pickles with his pride and joy as long as Pickles pays your travel and accommodation expenses. ![]() Melbourne is a lovely city to visit ![]() Am sure Pickles will be delighted with your workmanship! Brendan |
Ooops, bad habit
Brendan |
Except I don't have a Passport.
Forget the negative vibes Steve.
Be positive and go for it. Brendan |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
![]() ![]() ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I know this is an old thread but I need some help with the centre dash removal.
Having spent an hour yesterday trying to get mine out without success I have one question, Do you need to take the heater controls off in order to pull the centre dash clear enough to fit a new switch? Don't make old people mad. We don't like being old in the first place, so it doesn't take much to ![]() Richard |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
No you don't. If you unscrew the two bolts, then gently ease out the fascia from the clips holding it in place as per Steve's pics earlier in this thread, the fascia comes away with the cables connected to all the switches. If you are just adding another switch it is possible to do without even disconnecting any of the other switches.
The heater controls are not connected to the fascia and stay in situ You may need a plastic tool to prise the fascia off the clips holding it in place, especially the ones at the top. |
Thank you, that's a wasted hour that I will not get back, I had it all loose then tried to remove the heater controls, I need to get behind the cigar lighter to pick up the feed then insert the switch. Don't make old people mad.
no probs - I did the same took power from cigar lighter - was able to do it without even removing the radio.
