Home > Maintenance & Modifications > Radio & centre dash removal guide (picture heavy) |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Great Job !
Excellent very useful ! Thanks Steve Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
24th Sep 2013 6:23pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
Thank-you for the kind words. Sadly I think you are that bit too far away for me to do it for you. $W33T $0U7H3RN $UG4R
24th Sep 2013 10:26pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
TUT, TUT, Steve, lose the negative attitude.
Your response should be more proactive and helpful. Something along the lines that you will be more then happy to assist Pickles with his pride and joy as long as Pickles pays your travel and accommodation expenses. Melbourne is a lovely city to visit Am sure Pickles will be delighted with your workmanship! Brendan |
25th Sep 2013 7:14am |
25th Sep 2013 7:15am |
Ooops, bad habit
Brendan |
Except I don't have a Passport. might find that a little difficult to get out this country. $W33T $0U7H3RN $UG4R
25th Sep 2013 8:02am |
Forget the negative vibes Steve.
Be positive and go for it. Brendan |
26th Sep 2013 8:24pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4660 |
1982 88" 2.25 diesel
2nd Oct 2013 5:12pm |
I know this is an old thread but I need some help with the centre dash removal.
Having spent an hour yesterday trying to get mine out without success I have one question, Do you need to take the heater controls off in order to pull the centre dash clear enough to fit a new switch? Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
18th Nov 2018 8:40am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
No you don't. If you unscrew the two bolts, then gently ease out the fascia from the clips holding it in place as per Steve's pics earlier in this thread, the fascia comes away with the cables connected to all the switches. If you are just adding another switch it is possible to do without even disconnecting any of the other switches.
The heater controls are not connected to the fascia and stay in situ You may need a plastic tool to prise the fascia off the clips holding it in place, especially the ones at the top. |
18th Nov 2018 9:07am |
Thank you, that's a wasted hour that I will not get back, I had it all loose then tried to remove the heater controls, I need to get behind the cigar lighter to pick up the feed then insert the switch. Don't make old people mad.
18th Nov 2018 9:15am |
no probs - I did the same took power from cigar lighter - was able to do it without even removing the radio.
18th Nov 2018 10:40am |
