Home > Puma (Tdci) > Mantec RAI height? |
Photoguy1510 Member Since: 02 Apr 2013 Location: Wellington Posts: 25 |
Unfortunately, yes about 1.5" i can measure it tomorrow and give you the exact height above the gutter from bottom of gutter. Sorry car is at stealers for the night. 2013 Orkney Grey 110 SE on order should be here on 20/04
2nd Oct 2013 10:45am |
Kitoper Member Since: 07 Dec 2012 Location: Geneva Posts: 204 |
Hello evisu, I am travelling at the moment, but will be back tomorrow and can send some pics. I have the OEM RAI which is the Mantec one. It is at higher than the front cabin roofline, but not higher than the roofline over the loadspace. I also have a garage height problem so am sensitive to your question.
2nd Oct 2013 10:57am |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
The top of my Landrover(which I believe is the same as the Mantec one) one is 1945mm above Ground. This is based upon standard front suspension, but with 265/75r16 tyres. A more accurate measurement may be from the underside of the roof gutter which is 180mm. The top of the roof is generally 190-195mm at its' highest point above the underside of the roof gutter. Hope this helps |
2nd Oct 2013 12:07pm |
if its a LandRover RAI it is made by Mantec but it has a wider lower profile head if you buy from Mantec they are not allowed to sell you the exact OEM model so it has Mantec on the side where the LR one has Defender and the head is different.
If you look at the photos you will see the top of the mantec RAI is inline with the bottom of the roof rack crossbars which is well clear of the roof. Click image to enlarge Click image to enlarge LR Version Click image to enlarge 2013 Orkney Grey 110 SE on order should be here on 20/04 |
2nd Oct 2013 1:12pm |
evisu140 Member Since: 13 Sep 2013 Location: E Yorks Posts: 11 |
Here's some pictures to demonstrate my concern. I think the advice provided answers my question. Looks like I'll be ordering/fitting a RAI sharpish! Huge thanks to all that responded!
[URL=] Click image to enlarge[/URL] [URL=] Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
2nd Oct 2013 1:20pm |
