Home > Technical > Using Tow Connector for Battery Conditioner connection?
Trevor Wright
I've read on this forum or elsewhere that it is possible to use the towing electrical connector to conveniently attach a battery conditioner/charger (CTEK etc)? This avoids the need to open the seat box; have the door ajar and hence the vehicle can remain locked and alarmed.
I have a 13-pin Euro towing connector which is my only external electrical interface on my 2008 2.4 Puma 90. I've found connecting the eyelets on my CTEK conditioner difficult as the battery terminal screws are designed to tighten the connectors on the terminal posts and don't have any convenient flat surfaces.
Is this tow connector suggestion correct and safe? Trevor Wright
'08 90 TDCi/TD4 XS SW
Post #269883 28th Sep 2013 8:12am
Thumbs Up
Done on mine - see post here:
http://www.defender2.net/forum/topic17923....p;start=15
and due to position of battery probably a far safer and definitely more convenient solution, especially if vehicle is not garaged.
Post #269888 28th Sep 2013 8:26am
K9F
Group buy available here:
http://www.defender2.net/forum/topic23325.html?highlight=ctek
Adaptor available here:
http://www.disco3.co.uk/shop/index.php?act...oductId=45 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #269891 28th Sep 2013 8:37am
Trevor Wright
OK thanks everyone - adapter now on order - looks a very neat solution. Trevor Wright
Post #269951 28th Sep 2013 3:18pm
