Home > Td5 > Td5 running cool / overcooling |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6573 |
Just noticed yesterday on a motorway run that the temperature gauge was reading lower than normal.
Yes, I'm aware that Td5s normally read just to the left of vertical (and it always has until yesterday) but this is significantly further round to the left than that. I'm thinking that this can't be anything else but a duff thermostat? Seems to warm up OK though Pic just after getting off motorway: Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
30th Aug 2013 10:23am |
When you are off the motorway is the temp ok?
Have you checked the coolant level? With the engine running, gently unscrew the air bleed screw on the coolant hose .. Hopefully some water will come out ... Check your viscous fan? |
30th Aug 2013 11:55am |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Mine always runs about there summer and winter changing the thermostat made no difference 2005 Td5 90 XS
Steve |
30th Aug 2013 8:29pm |
John, the data would be handy, yes please - can't find any info in RAVE.
Done all the usual checks but nothing showing up 1988 90 Td5 NAS soft top 2015 D90 XS SW |
31st Aug 2013 10:22am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5575 |
Are all other gauges, lights ok? Could it be an earth issue? My temp gauge will twitch when I turn something else on or off.
Andy |
31st Aug 2013 10:25am |
james975 Member Since: 07 Nov 2009 Location: Edinburgh Posts: 53 |
I had the same problem.
It was the earth under the drivers seat next to the ecu. cheers James |
11th Sep 2013 6:54pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Mine sits about there.
11th Sep 2013 6:57pm |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 365 |
my temp always sits there, and when i have been booting it for a small while or towing up a hill it does raise slightly, it must be ok, coz my kenlow coincides with that and starts when the needle has gone up a fraction.
27th Sep 2013 2:51pm |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 |
It could be a broken spring in the fuel cooler? Just seen this on a 99 disco.
27th Sep 2013 6:02pm |
