Home > My Defender > Defender Hunter Edition
Page 5 of 7 <1234567>
Kitoper
Switzerland
Nakatanenga Rear Wheel Carrier
After months of waiting, I finally received the Nakatanenga Rear Wheel Carrier. Good things come to those who wait Very Happy
The installation was relatively simple even without any instructions aside from a picture as to what it should look like in the end.
The final installation came down to trial and error, and some instructions posted by Brendan on the forum a few weeks back which instructed the removal of the rear door interior trim.
First step is to effectively remove the rear trim so you can access the bolts that support the standard Defender Wheel carrier. Removing the rear trim is a question of unsrewing the grab handle beneath the window, and then gently pulling the trim starting at the top right corner and moving down and over.
Rear trim removed:
Rear Support:
After removing the rear support, you are then ready to attach the Nakatanenga door piece using the original wheel carriers nuts and bolts:
Then it is a question of trial and error in finding what bolts to use where when attaching the wheel carrier. Nakatanenga delivers three bolt lengths. Long, medium and short. The long ones I concluded are for the extreme right. The medium for the centre, and the short bolts for the left of the carrier.
Once you have bolted the wheel carrier to the cross member, it is time to connect the arm that will connect your door to the wheel carrier. This requires a little measurement and tightening, once at the right distance from the door you have two nuts that you can tighten so that your measure does not change.
Once completed, you have a wheel carrier that takes the load off the door, required no drilling, allows you to open the door easily and looks good. I liked the Nakatanega bear which is discreetly etched into the metal plate visible when the wheel is mounted. Very Happy
Post #268791 23rd Sep 2013 2:35pm
geobloke
Very nice, looks like a sturdy bit of kit. Is that silver piece a support bracket for when the carrier/door is closed? if you have not done so it might be a good idea to smear some grease on it... Thumbs Up
Post #269298 25th Sep 2013 8:34am
K9F
Looks like the hinge assembly for when you open the door. I wouldn't apply grease to that as all the crud will stick to it as it's quite exposed. The slider mechanism however I did pack full of grease to stop the crud and dampness getting in.
Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #269308 25th Sep 2013 9:36am
Kitoper
Switzerland
Good day gentlemen,
Geobloke, thank you for your comments. I am pretty happy with this piece of kit. The support bracket attached to the rear cross member support is not touching the wheel carrier itself when not in motion, but I suspect that when in driving it is there to provide some support. As a preventive measure I put glued a very thin strip of rubber to the support arm. This is there so that metal does not touch metal Confused
As per the connection to the door, it is a piece that reminds me of a mini tie-rod made for your front steering. It is a solid bit of kit, pre-greased and the rubber bushes are thick.
My rear door seems a lot lighter now and the problem I had when the wheel was on the door, where sometimes the door handle would block and require more force when opening has been eliminated. I don't know who Nakatanega sources this from, but it seems well made.
A couple of pics of the "Tie-Rod"
Top view
Post #269335 25th Sep 2013 12:08pm
Kitoper
Switzerland
K9F,
Your wheel carrier looks good too - is that the Safari carrier?
Post #269336 25th Sep 2013 12:09pm
K9F
Yes mine is the same principle as yours. Mine is indeed the Safari Equipement single pivot. Uncomplicated and very sturdy. Got it from a fellow forum member. 'Reworked' the bumperette bracket to get it to fit again afterwards.
Post #269375 25th Sep 2013 3:27pm
Kitoper
Switzerland
The Hunter has gone hunting
Three weekends in a row of hunting in the rain with my Defender which was built with hunting in mind Thumbs Up and she looks like a real Defender Very Happy
While out on the hunts I was thinking more of the hunt, dog etc that I did not take any pics but will try that this weekend.
I had to figure out how to protect my gun safe from my dirty dog who likes the panoramic view she gets from on top of the safe Dog I ended taking the rear load space protector of the XC90 we got rid of and used some plastic ties to attach it to the dog and luggage guard. It lifts up and allows access to the safe while protecting the safe from my wet and dirty, yet faithful friend.
Post #276076 23rd Oct 2013 4:55pm
Kitoper
Switzerland
A minor change to the Hunter. Eric finally convinced me that Nokian tyres were the right choice for the winter. I had seen the Wolf wheels on his, so these were already on my wish list.
The Hunter has just received a pair of Wolf rims with Nokian LT2 tyres for the winter. They were tested on dirt roads after rain (=mud) two days after being mounted. Conclusion - they are exellent in mud - still to confim in Snow.
Aside from the performance, I also believe they enhance the look of the Hunter.
Post #300842 21st Jan 2014 12:46pm
ericvv
Those Wolfs look really great on your Keswick Hunter Thumbs Up
For anybody here in Switzerland who might still be interested for his Defender in a set of 4 of these winter rims and tire combo, please note that Land Rover Switzerland only have one of those sets left now. Two left wheel and two right wheel..... Thereafter it is game over until they put together a new batch ahead of next winter.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #300878 21st Jan 2014 2:41pm
Kitoper
Switzerland
Thank you to my Defender Mentor Thumbs Up It is great to have someone like you who I can bounce ideas off of, who can give advice and with whom can share projects.
Speaking of projects, next up are:
Hella Luminator Compacts
Mantec Upper Load Lugga - Nick at Mantec is a great source of info and offers fantastic service.
Post #300881 21st Jan 2014 2:48pm
SachaR
Italy 1995 Defender 90 300 Tdi CSW Stornoway Grey
Wow! Serious engineering there for a wheel carrier!! 1995 300TDI CSW 90
1968 Mini Innocenti
Post #300885 21st Jan 2014 3:12pm
Kitoper
Switzerland
Hella's
As you can imagine, with 6 children as a priority, investments in my Defender are timed. In addition, I was looking for Auxiliary lights that would be modern (led) while at the same time respect my intention to keep the "OEM" look.
After much research and a discussions with Hella in Germany, I found these:
http://www.hella.com/MicroSite/offroad/UK/...LED_GB.pdf
I went with these :
Spotlight (heavy-duty) with black design ring, ventilation hose and T-piece 1F3 011 815-031*
I find that they compliment the Noldens, are not too big on the A-Bar and above all are bright enough for my needs.
Here are a few pics taken in the garage with my Iphone, so not great but posted for the benefit of SkyFallSilver Smile
Close ups
Side View
I have them wired so that they are EE compliant and come on through the dash switch only when the High Beams are on, but I also have a second switch which allows me to turn them on when the Defender is switched off.
Post #327458 1st May 2014 7:40am
ericvv
I have seen them working, fantastic. Probably worth to take a few more good pictures of when they are "on". If I did not have the SVX front, this would be my choice too. Thumbs Up
One more comment, the posted Iphone pictures in my opinion do them not much good and are a bit misleading even. In reality they are the perfect match for the Nolden, as the diameter of both is also identical.
Post #327504 1st May 2014 10:39am
Kitoper
Switzerland
You are right, will get her out this weekend and take real pictures. Very Happy
Post #327519 1st May 2014 12:20pm
Kitoper
Switzerland
Double post - so I deleted one
Post #328476 5th May 2014 8:56am
