Home > Puma (Tdci) > Occasional Starting Problem
Page 2 of 2 <12
Skye_Rover
Scotland 1998 Defender 110 300 Tdi CSW Cairns Blue
[quote="skyeplumb"
Do you know what the volatges should be for a healthy battery - also what is the spec for the correct OE (or better) battery? I might just get a new one as winter is fast approaching and I cant afford a failure.
[/quote]
Clive, depending on the state of charge, a battery will read approximately 12.6v when lightly charged, and 13.2v when fully charged. There are very slight differences from technology to technology. You also need to make sure that you read the voltage after the engine has stopped for several minutes, as you can get a false reading if the battery has recently had a charger or alternator re-charging it. Another crucial test is to measure the terminal voltage whilst the starter motor is under load; if the battery droops down on voltage too much (less than 9.5v), then it is also on the way out. Old batteries can quite often look good on a voltmeter, until they are put under load.
If you really get stuck, you could search-out your friendly local auto electrician with an oscilloscope to map the starting currents and voltages! Roads? Where we're going, we don't need roads.
Post #269258 24th Sep 2013 10:33pm
skyeplumb
Scotland 2007 Defender 110 Puma 2.4 USW Rimini Red
Thanks SkyeRover, I think I'm just going to buy a new one as the capacity is only 72ah the voltage has dropped overnight and I'm getting starting issues.
Are there any advantages to a genuine LR over others like Bosch?
Clive Series IIa Lightweight - Long Gone
Discovery 1 300Tdi - Sold
Defender 110 XS 07MY Utility
Post #269275 25th Sep 2013 6:52am
Longer lifetime, mine is 6 years old and still going strong. Shocked the Bosh is cheaper so probably why it was fitted. $W33T $0U7H3RN $UG4R
Post #269289 25th Sep 2013 7:56am
Skye_Rover
The original Landrover unit is a Yuasa OEM battery. You could save a bit of money by just buying a decent battery of the correct size from Skye Auto Spares (which was just Yuasa as of this year), as that is what he deals with there. These seem to last well, and seem to recover from deep discharge fairly reliably - not that I would make a habit of it! I have had many batteries through Julian and Dave, so wouldn't hesitate to recommend SAS. You can get a decent battery in the compartment, so you are not fixed to just one type. If your old battery is on the way out, then you probably don't have anything close to the benefit of a 75Ah rating, and a new 90Ah will transform your electrical reserve. I am running a 105Ah on my 300Tdi, but would have to re-check the type number.
All the best Clive. Roads? Where we're going, we don't need roads.
Post #269407 25th Sep 2013 5:45pm
skyeplumb
I've had batteries fron SAS before and they do, supply at a decent price, bu I was going to Inverness today anyway so I bought a genuine from M&D, ill fit it in the morning.
Thanks for your expert advice as always
Very Happy Series IIa Lightweight - Long Gone
Post #269481 25th Sep 2013 9:47pm
skyeplumb
noticed the difference immediately - the engine starts instantly - you can hardly hear the starter turn its so quick.
Well let's hope thats the end of that little episode then
Cheers all for help and advice
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Series IIa Lightweight - Long Gone
Post #269568 26th Sep 2013 12:17pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
just FYI
- Puma OEM LR battery is a varta, TD5 was a Yuasa.
- It is not from their standard car battery range but a leisure deep-cycle type.(wet type so not AGM or gel but indeed deep-cycle) (somewhere in the threads on here i once did a write up where you can find the exact spec)
- Bosch selects and rebrands batteries produced by Varta. Their standard car series get a higher pricetag as they come with longer warranty terms (3-4-5 years depending on the series) compared to the Varta branded equivalent. Some sources also say that this is related to a post production testing/selection where bosch gets the premiums over Varta.
But these have nothing in common with the deep cycle type LR selected for the Puma from varta (there is no exact replacement from Bosh for the OEM Puma battery)
2cents Smile
Post #269579 26th Sep 2013 1:43pm
Page 2 of 2 <12
