Home > Maintenance & Modifications > Shelf for cargo area of 110? |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
I put a top shelf into the Utility. It sat at the same height as the gutter went from the back of the second row seats to about 3" from the back of the vehicle. Great for light stuff it seemed to have a tardis ability to take whatever you could shove up there
15th Mar 2010 1:59pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Now that's a bloody good idea as usual, photos please when next able Original Member Pie n Pea Club.
110 HCPU Tipper |
15th Mar 2010 2:25pm |
ti-fat-man Member Since: 08 Feb 2009 Location: Bedford Posts: 517 |
i've seen a shelf jobbie on the BOAB site...
15th Mar 2010 2:49pm |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 |
I am fitting the Mantec load guard and shelf. It may do the job.
http://www.devon4x4.com/products_a/p13564c...ef-07.html AndrewS sounds like a plan. Be nice if you had any pics or technical drawings 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
15th Mar 2010 3:37pm |
Alex e Member Since: 23 Apr 2007 Location: Home isn't it Posts: 204 |
Andrew you seem to have a lot of inner roof storeage ideas, i take it you don't use that area for anything normally then?
15th Mar 2010 3:41pm |
Well the 130 is going to have a built in Car Puter that will be located in an area on the underside of the rear of the roof.
15th Mar 2010 4:44pm |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
Looking at the mantec option too over the sliding drawings
15th Mar 2010 5:15pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Mantec is on Back order according to D4x4
15th Mar 2010 8:15pm |
I had a 3 month wait, not sure where muddy feet sourced it but am assured its arrived 59 2.4 110 XS Utility
15th Mar 2010 9:08pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Thanks for the suggestions all... I should've added that I'm looking for something that is solid, rather than a grate.
We used to have a Jeep with a thing that rolled out and hooked on to the back gate, to hide your loot. It was fabric though, kind of like a blind, and you couldn't put anything on it. |
15th Mar 2010 10:14pm |
jddisco200tdi Member Since: 22 Jul 2008 Location: Melbourne, Australia Posts: 21 |
You want something like this ?
Any carpenter should be able to knock up the shelf for you. Regards John D - Defender 110 2.4 |
15th Mar 2010 10:33pm |
I like that last one...
guard just above the seat backs, and that shelf looks like it has a seat belt fastening, allowing it to drop down i presume.. is it custom fabricated or available through retailer? al. |
16th Mar 2010 9:43am |
That is exactly what I'm after... thanks for posting the pic! |
16th Mar 2010 8:08pm |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
The Boab ones are OK, but can easily be made for a lot less, I think the one in my old 90 cost about £10 2002 Defender 110 DC
16th Mar 2010 9:17pm |
