Page 572 of 1377 <123 ... 571572573 ... 137513761377>
shaggydog
Sorted some minor issues and then my viscous coupling decided to give up on the way home...
Something about painting a scottish rail bridge? i dunno....
Post #268663 22nd Sep 2013 9:42pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Spent the weekend at our van in The New Forest
Had some visitors while packing up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #268664 22nd Sep 2013 9:43pm
Pickles
Sockpuppet wrote:
Wow, didn't realise it was such a common issue. I might look at those.
Haven't got our 90 yet, but I'm aware of the problem, & I've seen these. Only thing I don't like about them is that holes have to be drilled?
Cheers, Pickles.
Post #268668 22nd Sep 2013 10:02pm
Sparkzter
Yeah, the corners wear badly. Not too keen about them being drilled in either.
Post #268675 22nd Sep 2013 11:00pm
Cheshire110
Cheers, Pickles.
You could always just glue them down? Cheers, David
Post #268677 22nd Sep 2013 11:06pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
WarPig wrote:
Rakthi wrote:
Drained the oil, didn't put bucket in the right spot (the oil shoots surprisingly far once the drain plug is completely removed) and spend a nice half hour cleaning up oil. Good thing I had put a tarp down.
2 rolls of paper towels and our whole supply of rags later everything as good as new.
This being the sub tropics (26°C is cold here) and Malaysian diesel being 500 PPM if not more, decided to go with "Fuchs TITAN UNIMAX ULTRA MC 10W-40" Put in 6.75 litre of the stuff.
Fit a Difflock Drain Plug, no more oil spills...
http://www.difflock.com/drainplug/
Will order one so can put it on in a couple of months when oil is due for a change again. Thanks for the tip! Thumbs Up
Post #268683 23rd Sep 2013 3:15am
Super pictures Bob Thumbs Up
Applecross area ?
Post #268691 23rd Sep 2013 6:49am
bob neville
Yep, all around Applecross Thumbs Up
Superb weather, few showers on Wednesday and that was about it. All the rain was over Skye and to the south which made for some spectacular views.
We walked to the coral beach and the tide was out. Thought nothing of it but back at the car we got talking to a couple of locals who told us that it was one of the best places of see otters - especially when the tide was coming in Big Cry
We can thoroughly recommend Applecross, the walking and scenery are second to none. We stayed at the Applecross Inn, excellent place and the food is to die for especially the Haggis and the fish Thumbs Up
Only problem we had was with the D7000, it decided to throw oil onto the sensor from the mirror box ( not uncommon) but I cleaned the sensor yesterday and it is all OK now - until it does it again !
2013 Defender 90 CSW - sold
Post #268695 23rd Sep 2013 7:05am
Washed both of mine. gleaming now! Mr. Green
Post #268697 23rd Sep 2013 7:11am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Bob
Off-topic, but I've always thought cleaning DSLR sensors was a tricky job. Do you have any tips for doing it..? Mine has a small dust spec that causes problems and I'd like to clean it.
Simon
Ps great photos and trip.. Wink
Post #268698 23rd Sep 2013 7:16am
bob neville
Off Topic answer !
I think there is a myth spread by camera manufacturers and shops that cleaning the sensor will destroy the world - it is not true ! What you are actually cleaning is a glass filter over the sensor.
Simple steps.
1. Fully charge your battery, this is very important as the camera will be on when you lock the mirror up. Damage WILL happen if the battery loses charge and the mirror drops.
2. Remove lens, turn camera on and lock mirror up - follow the menus as to how to do this.
3. Check filter with a strong light and magnifying glass - you will see the dust specs. If you have a spec in the bottom right of a picture the dust will probably be in the top right as you look at the sensor.
4. Turn camera so the lens opening is facing down and use a bulb blower to blow into the opening. If you are lucky this will remove the dust and that is the job done. If not it is a wet clean.
5. http://www.cameraclean.co.uk/products.php?...ools+-+Wet - get some fluid and paddles from here.
6. Wet a swab as directed and place on the LH side of the sensor. Move to the RH side with moderate pressure, the handle should bend. Having gone left to right move the handle so you use the other edge of the swab and go right to left. lift swab out and throw away (one use only).
Repeat 6 until the dust has gone. believe it or not the dust can bake on the sensor so you may need to repeat stage 6 a few times.
Dust on DSLR sensors is a simple fact of life - it will happen. Some brand new cameras have sensor dust so even the clean manufacturing environment will not stop it happening.
I have actually seen a pro clean a sensor with dry Q tips, I would NOT suggest this !, but he said he had never damaged a sensor and and his pictures are crystal clear.
Post #268701 23rd Sep 2013 7:38am
couplands
Thanks Bob, a job for today...Wink
Simon
Post #268703 23rd Sep 2013 7:55am
x-isle
bob neville wrote:
Off Topic answer !
Simple steps.
Bob
You are right, I used to clean my sensor all the time.
However, if it goes wrong, it goes wrong big time. I never even bother raising the shutter anymore (apart from when I want to use a blower to blow dust off). One clean I did ended up costing my over £700 to put right.
A small dust/grit particle (that I couldn't see) got on the sensor and I ended up putting one big scratch across it, I had to have a complete new sensor assembly fitted.
For the sake of a few quid, I just get mine cleaned professionally these days as saving a few quid cost me over £700.....
If you do attempt yourself, take a gander at http://www.parkcameras.com/article/246/Dig...aning.html
Lots of good advice on there.
I also have an old Nikon D70s (still a great little camera) and as this isn't worth that much, I do clean that sensor as it's no big deal if I have to replace that one.
The D7000 does have an issue with oil deposits, I believe Nikon had a deal that the first clean was free at a service centre, it's due to the shutter grease. It should only happen when the camera is new or has had a service which is why there was a first free clean. As I had a new sensor fitted to mine, I think Nikon regreased the shutter and it now needs a clean again. Shutter was changed about 18 months ago.....and I still cry at it now. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #268721 23rd Sep 2013 9:44am
Arran73
Put my winter rims on as well as added an A bar
Post #268738 23rd Sep 2013 11:07am
Arran73
Post #268739 23rd Sep 2013 11:08am
