Home > Stolen > TDci doors stolen
Page 2 of 2 <12
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Couple of hundred people collectively saying 'ah' Shocked
Post #267737 18th Sep 2013 7:33pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
I have different security on the hinge bolts inside.
They would need some thing special to get my hinge bolt out.
If they want it they will take it eventually but let's say it slows them down and they may find easier pickings
Post #267740 18th Sep 2013 7:45pm
K9F
Retroanaconda wrote:
I assume you guys also fit security nuts to the hinge bolts on the inside of the door?
There's no point in fitting ball bearings to the heads if they can just open the door, whip four M8 nuts off and lift it off the hinge.
And what about the hinge pins? How do you stop them just knocking those through in 30 seconds with a centre punch and taking the door off that way?
Maybe I'm missing something here but the hinge bolts are captive and not accessable from the inside. My aftermarket stainless hinges the pin isn't exposed either???? A cheap modification that prevents easy access through the doors to the inside of the truck. Better than doing nothing and scoffing at others ideas perhaps?
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #267765 18th Sep 2013 9:01pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
No nuts where the flats round off when you try to undo them are standard fit on defenders! Wink Wink Wink
Post #267777 18th Sep 2013 9:34pm
Retroanaconda
Whistle
On all mine the bolts pass through the hinge and the door and are secured by an M8 nut on the inside tucked beneath the door card. Have they changed the design so there is an M8 nut incorporated into the door frame itself now? Obviously on the bulkhead side there are captive fittings there.
After-market hinges - fair enough. But on OE ones the pins can be knocked through very easily.
Even if it was all infallible it wouldn't prevent access to the inside of the "truck", we all know how poor the door locks are. Failing that they'd just break a window, or pop one out of its seal, and open the door from the inside.
I'm not scoffing at anyone's ideas, the more obstacles in their way the better, just highlighting the issues at hand. From my point of view it's not really worth trying to prevent access into the vehicle, you're better off trying to stop them starting/moving it if anything at all. But then I haven't got a new shiny one where the doors are worth more than the rest of the car - finally an advantage to rotten old doors!
Post #267939 19th Sep 2013 6:11pm
K9F
I have embraced the layered approach as much as possible. Door side mine were M8s but are now rivnuts. One of the main reasons for the fitting of Landyglass was to prevent sliding window forcement or popping out the rears. It's down the the individual how much to spend and how much you value your truck. As mentioned doing 'something' is better than doing nowt. Agree it still won't stop some scrote with a brick smashing a window or an angle grinder cutting another way in, but I do sleep sounder in my bed knowing I have taken certain measures. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #267984 19th Sep 2013 9:05pm
Page 2 of 2 <12
